Results 1 to 20 of 20
Thread: best weight oil for my b16a2 w/160k
    Atlanta, Ga
    Default best weight oil for my b16a2 w/160k
    just as the title says... what do you guys suggest i run in my 160,000 mile old b16a2. i have 5w30 in it currently just because that's what the cap says. idk... feels like it thins out really quick, but that's just speculation.
    please post.
    Augusta Ga
    run 10w30 full synthetic mobil 1 .... end thread
    93 sol Si
    95 sol S
    95 sol Si
    Atlanta, Ga
    well idk if i want to go synthetic yet... that **** is retardedly expensive. it costs almost $20 more to get it changed with synthetic.
    Metro ATL
    ^ agreed.
    Turbo-Wired
    East Cobb
    With 160k on the motor, if you've NEVER run synthetic, there's a few risks involved too. If you have any oil leaks from where the seals are damaged or almost gone, the Synthetic has SO MUCH detergent power that it can tear straight through what's left and leave you with a much more significant oil leak. The best bet for what oil to put in your car is the oil you're using now, and simply change it more often. 2000-2500 miles should keep the oil in the car fresh and clean after the first few changes, as the increased cycle will actually help clean everything out of the engine even better than the engine flush kit stuff does if you give it time.
    any 10w30
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    75w95 ftmfw!!!!!!!!!!!!!!!!!
    98 Acura Integra LS-DD
    ??????????????????-project
    Stang Mod slostang's Avatar
    Southside
    my d15b7 has 213,xxx miles on it and I've been using mobile 1 clean 5000 in 10w30 and I fully recommend it!!! it's not all that expensive either.
    Southside
    Quote Originally Posted by 95egex
    that's rear end dope.
    if you put 75w95 in any engine it WILL fućk it up. oil pumps weren't made to handle anything that thick.
    I use 10w40 in the summer, and 5w30 in the winter
    Atlanta, Ga
    yeah my B seems to be pretty healthy, not a drip of anything leaks, but i'm still scared of synthetic. alright well i will probably go to 10w30 within the next month or so and i guess that'll do.
    synth would be fine
    Atlanta, Ga
    i'll go synth probably when i get a few more miles on her.
    TALKING ROCK, GA
    Quote Originally Posted by slovic
    if you put 75w95 in any engine it WILL fuæk it up. oil pumps weren't made to handle anything that thick.
    dude, it was a joke...
    Hamilton, GA
    jus by the oil from advance or a parts store and DIY
    Or bring your own oil to wherever you get it done at and pay the $10 for labor
    It's all about JDM.
    CA to GA
    Use Castrol syntec 10W40, or if you too afraid of the side effects, use just the standard Castrol 10W40 (white bottles w/ the green cap). In my opinion, Castrol oil performs much better than any other brand, and is recommended for Hondas. But if you decide to use Castrol, I'd suggest doing a proper oil flush, and time to start learning to do oil change urself man...
    한 국
    mobil 1 fully synthenic 10w 30 high mileage
    turbos
    If u want to use synthetic you should start blending it into your engine. For instance if ur car takes 3 1/2 quarts use 2 1/2 quarts conventional and 1 quart synthetic and start going up on the amount of synthetic every time you change ur oil.
    TOO BIG
    jupiter
    i run 5w30 full syn mobil 1 in my joint! walmart has it for 22.96 usually (5qt jug) liquid gold FTMFW!!
    schweet Shibby's Avatar
    Sep 2008
    Hogansville
    238,800 miles on my b16a2
    runs literally perfectly exactly the same since 3 years ago when i bought it.
    religiously use Mobil1 full synthetic 10w30 in winter, 5w30 in summer.
