Results 1 to 16 of 16
Thread: 03 accord getting horrible gas mileage
    Default 03 accord getting horrible gas mileage
    i drive an 03 accord 4cyl. my gas mileage has been progressively getting worse. is there anything i can do to fix that? thanks.
    Stone Mountain
    try to run injector cleaner through it. could be a bad O2 sensor. could be a bad cat. and i know the timing was off in my mustang and was makin me get HORRIBLE gas mileage
    Senior Member jfman's Avatar
    First of all what kind of mpg are you getting? Did you sit down and calculate it? BTW: It goes 200 miles on $60 of gas is not MPG.
    How many miles? Maybe its time for a new primary O2 sensor.
    turbos
    time for a tune up maybe? how many miles are on it?
    TOO BIG
    lost 3'' in 3 hrs!!! 1moreaccord's Avatar
    l'ville
    Try driving like grandma.. Pinky toe the accelerator lol..
    But also try simple little things.. like replace air filter.. Oil change.. maintenance stuff..
    Trogdor!!! IOnlyLookStock's Avatar
    Quote Originally Posted by seanrg1116
    x2!! On my old honda I did new plugs, wires, oil change, and air filter change and gained 4-5 MPG.
    Project Seksie DailyDriver : '74 Firebird 455
    The Beast : '01 Transam
    The Grocery Getter : '09 Fit. The fit is go...
    Scottish Scotsman's Avatar
    on the road to recovery
    possible bad MAP sensor
    Senior Member G.C's Avatar
    Forgot
    not enough info.
    :idb:
    thanks for all the help by the way. i have about 73000 miles on it. ive been keeping up with the oil changes. i was thinkin it was time for new air filter and i also heard new spark plugs would help. im not sure EXACLTY what my mpg is but usually if i start on a full tank i would get 350-400 until the light came on. and now i get about 300-320 from full tank until the light comes on.
    turbos
    Quote Originally Posted by phatzboyal
    K&N FTMFW
    buy it now dont delay
    http://www.1aauto.com/1A/HighPerform...gn=google_base
    TOO BIG
    JDM TYTE AnthonyF's Avatar
    MANY things you can do:
    1. Raise the air pressure to 35-40psi
    2. dont shift pass 2k
    3. plugs
    4. wires
    5. fuel filter (if not in the tank)
    -Ant.
    The Carbon Fibered R6
    Jonesboro/Stockbridge
    You know you're driving habits can save you up to 20% more gas. If you drive with a lighter foot, braking and accelerating slower than you will save more gas.
    Its the most sure fire way of saving gas but you still might wanna check your air filter, tired pressure, spark plugs, and fuel filter.
    Senior Member Code-Aye's Avatar
    hahaha
    i would think maybe fuel filter
    Georgia Muscle twinj's Avatar
    Da "A" Niccuh
    I would def do Air filter and spark plugs first.
    EM1 Crew Member
    LUCUS FUEL TREATMENT
    1999 Honda Civic EM1 FBP (Current)
    1999 Honda Civic Ex VSM (sold)
    1997 Honda Civic DX MR (Sold)
    H-T EM1 Crew Member
    Oct 2003
    Is the check engine light on?
