Results 1 to 21 of 21
Thread: my radio sounds wierd
    Made in BRASIL junior_tm's Avatar
    Brasil
    Default my radio sounds wierd
    well i installed a amp 4 channel in my car and i'm using it on my speakers but when my car is on neutral and i'm stopped the car makes wierd noises when i press the gas, this happens when the rpm go up and down the sounds go up and down(not volume wise) any one have a clue thank you
    ToTaLMaDNe$$
    Yeah we roll and we ride
    In control, we don't stop
    We gonna glow where we drive
    Let you know we on top
    no accord
    alpharetta
    you have engine noise. it could be multiple problems. either your amp is junk, or your radio is junk. you may just have some bad rca's ( start with this first get some good rca cables, and try to keep them away from any power cables), also move your ground wire to your amp and make sure it is secure. is all else fails just buy a noise filter with rca out and rca in, and the noise will be gone.
    RESIZE PIC PLEASE
    DBlock
    tha ville
    Quote Originally Posted by sina518
    ........most of the time your RCAs are too close to a power wire!!!!!.....gets annoying after sometime!!! ....1
    youre an idiot,please refrain from opening your mouth when you dont what youre talking about...
    sina is right..it could be junk amp or radio..it could be bad jet of rca's..or it could be a bad ground..make sure your radio and amp are grounded properly..and also what kind of equipment do you have
    vtakkk hondaxpurt's Avatar
    TALKING ROCK, GA
    probably a bad ground. try a bigger wire and make sure its snug on what its grounding to. make sure there is no paint, just bare metal. 99% sure its ground issue
    98 Acura Integra LS-DD
    ??????????????????-project
    no accord
    alpharetta
    Quote Originally Posted by b@d @pple
    i was taught by you.
    RESIZE PIC PLEASE
    no accord
    alpharetta
    Quote Originally Posted by 95egex
    i really don't understand how your 99% sure
    RESIZE PIC PLEASE
    TALKING ROCK, GA
    because i am pretty sure he is talking about the "whining" noise coming through the speakers and that usually means a bad ground. i am assuming thats what he is talking about
    I GOT IT!
    Jan 2003
    Lithonia, GA
    the process of elimination would be the best bed starting with the source unit and working from there
    Hybridaccord
    ______________
    Ditto, you both know exactly what you are talking about, the entire body of the vehicle is a ground conductor which can induce noise and is typically the problem.
    http://www.carsound.com/columns/navone/nav0005.shtml
    www.canze.org.nz/forum/attachments//Trace_Noise.doc
    here is a link to help you in the process of elimination.
    DBlock
    tha ville
    whoa wtf are u talking about???!!!!....i put "im with stupid" in that post because sina is correct and ive had the same problem with a system in my car!!!........1
    Brasil
    i got a alpine radio and a coustiq 4 channel amp when i had the system running it was not making the noise after 2 week or so started i'ma check tomorrow and i'll let yall know reps for the help
    thank you
    ToTaLMaDNe$$
    misread..sorry
    Level 1: Check out the Amplifier(s)
    After you have determined that there is noise in the system, determine
    if the amplifier is causing the noise. To do this, mute the signal at
    the inputs to the amp by using shorting plugs. If there is no noise,
    then the amp is fine, and you can proceed to level 2. However, if
    there is noise, then use a test speaker at the amp's output. If this
    stops the noise, then the problem is originating in the speaker wiring,
    or the passive crossovers. Check to make sure that none of these are
    shorting with the body of the car, and start again at level 1. If
    noise is still present when using the test speaker, then there may be a
    problem with the power supply on the amp. Try connecting an isolated
    power supply - if this does not get rid of the noise, then there is
    something seriously wrong with the amp, and it should be replaced. If
    the noise goes away, then there may be a problem with power supply
    filtering or isolation. This can be fixed by changing the amp's ground
    point or by adding external supply filtering.
    Level 2: Reduce the System
    The amps have been determined to be noise free. If you have any
    processors between the head unit and the amps, disconnect them and
    connect the head unit directly to the amp. If this gets rid of the
    noise, then one (or more) of the processors must be at fault, so
    proceed to level 5. Otherwise, try running the signal cables over a
    number of different routes. If you are able to find one that does not
    produce any noise, permanently route the cables in the same manner, and
    proceed to level 5. If not, then you must isolate the head unit from
    the car's chassis (except for its ground!) - don't forget to disconnect
    the antenna, since it is also grounded to the car. If isolating
    the head unit does not solve the problem, the move the grounding point
    of the head unit. Hopefully the noise will be gone, and you can
    install the head unit with a quiet ground and proceed to level 5,
    otherwise go on to level 3.
    Level 3: Move the Head Unit
    The amplifiers are fine, but moving both the ground for the head unit
    and the signal cables does not solve the noise problem. Take the unit
    completely out of the dash, and put it on either the seat or carpet,
    and run new signal cables to the input of the amp. If this solves the
    problem, re-install the head unit, one step at a time and skip to level
    5. But if the noise persists, then move the head unit as close to the
    amp as possible and use the shortest possible signal cables. This will
    verify that the original signal cables are not causing the problem -
    assuming the noise is gone, reinstall the head unit one step at a time
    and go to level 5. Otherwise, there may be a problem with the power
    filtering for the head unit. As with the amps, power the head unit
    with an isolated power supply (again making sure that the head unit
    isn't touching the car's chassis at all). If the noise goes away, you
    can add power supply filtering or an isolated power supply; go to
    level 2. But if the isolated power supply does not solve the problem,
    then you can either replace the head unit and go to level 2, or check
    the car's electrical system in level 4.
    Level 4: Testing the Car
    There does not seem to be a problem with either the head unit or the
    amplifier, and the car's charging system is suspect. To see if this is
    the case, we can use a system in a car that is already known to be
    "quiet." Bring both cars together as if you were going to jump one,
    and use jumper cables to connect the two batteries. Start the engine
    of the car with the noise problem, and listen to the "quiet" car's
    system. If the noise does not go away, there is a SERIOUS problem with
    your car's electrical system (possibly a bad alternator). Have a
    qualified mechanic check the charging system out. If there is no noise
    in the "quiet" car, then the "noisy" car's charging system is
    definitely quiet, so continue with level 5.
    Level 5: Adding Signal Processors
    We have proven that the amplifiers are good, the head unit is good, and
    the car's electrical system is good. Now we need to reconnect each
    signal processor. Repeat this level for each signal processor used in
    your system; if you have added all of your signal processors, and
    there is no longer any noise, CONGRATULATIONS! You've removed the
    noise from your system! Connect the signal processor. If there
    isn't any noise, then go on to the next signal processor. Otherwise,
    try re-routing the signal cables. If this cures the problem, then route
    them permanently over the quiet path, and install the next processor.
    If not, then isolate the processor from the car's chassis except for a
    single grounding point. If this works, then permanently isolate the
    processor, and move on to the next processor. If isolation does not
    help, then advance to level 6.
    Level 6: Processor Isolation Tests
    Now, noise enters the system when one particular processor is
    installed, but regrounding it does not help. Move the processor very
    close to the amp, and check for noise again. If there isn't any, then
    re-install the processor, carefully routing the cables to ensure no
    noise, and continue at level 5 with the next processor. Otherwise, use
    an isolated power supply to power the processor, making sure that no
    part of the processor is touching the car's chassis. If this solves
    the problem, then consider permanently installing an isolated power
    supply or possibly a 1:1 transformer, and go to level 5 with the next
    processor. Otherwise, separate the processor and isolated power supply
    from the car by many feet and re- test. If there is still noise, then
    there is a serious problem with the processor's design. Get a
    different processor, and continue at level 5 with it. If separating
    the power supply and processor from the car does solve the noise
    problem, then either the processor is damaged, or your tests were
    inaccurate. Repeat level 5.
    your moms bedroom...
    that was ****ing rude!
    DBlock
    tha ville
    Quote Originally Posted by rollinls
    dont trip!!!!! its cool.......he mis-read!!!!! ....1
    Milano Pink ftw
    Columbus, GA
    your rca's are ran down the same side of the car as the power....common practice with a 4ch amp is tho have run them on the opposite side of the car.
    94 Honda Del Sol VTEC
    02 WRX patrick4588's Avatar
    warner robins
    Quote Originally Posted by Ails85
    only with 4 ch amps? lol. you should do that all the time!
    GCO Member
    NRA Member
    Brasil
    i didnt get that anyways how do i do dat hehhee
    ToTaLMaDNe$$
    warner robins
    um... pull the paneling on both sides of the car. undo the power wire or rca's and route them on the other side.
    GCO Member
    NRA Member
    Milano Pink ftw
    Columbus, GA
    Yes, with subs(mono, 2 ch amps)...Most of the time you can get away with running them down the same side with no problems at all, but with 4ch amps its a must.
