Thread: Catastrophic failure
    Monore/Atlanta GA
    Default Catastrophic failure
    Background: I rebuilt my motor for my 87' Chrysler Conquest Tsi and finished it back in May but had a knock that I couldn't figure out after the initial start up, and then the second time I drove it it fell apart. I made it home but barely.
    It's not pretty. I finally got around to pulling the motor out after it failed not even 50 miles after initial start up.
    I pulled the head completely off and inspected the #4 cylinder as I had felt around it before and it seemed to have some cracks in it, so I thought the block cracked.
    Here is what I saw when I got the head all the way off.
    So here I can tell something has went bad and wore a nice spot in the side of the cylinder wall. Not good.
    After much more time and work I got the engine completely out of the car and drained the oil pan.
    I drained about 10+ quarts of fluid out of the oil pan, it seems that ALL of my antifreeze was in the oil pan. Oh, and my magnetic oil plug was covered in crap.
    I finally got the oil pan off after the draining and pulled these lovely jewels out of the pan.
    Then I got the #4 piston out and low and behold the culprit showed itself
    I guess now I know what that knocking was that I couldn't find. It must have been a loose wrist pin or something and then when i got it to highway speeds it gave out. Now I have to start all over from scratch. I am tired of this motor and I haven't even got to drive the car but a couple times for a few minutes. I want to pull my hair out. Now what do I do? I guess back to the drawing board.
    Do you think I can trust the other 3 pistons? Is there a way to verify they are sturdy enough?
    I will tare the rest of the bottom end down later but for now I guess I will need to collect some new parts before moving forward.
    01' Mercedes C320 $10500 o.b.o. or trade 4 G35 coupe
    http://www.importatlanta.com/forums/...9#post38098929
    IMO, do it right the first time. you dont want to just fix #4 and put the whole motor back together, then #2 takes a **** on you or something like that a week later. while you are at this stage, go ahead and check the rest of the motor out. just my
    Monore/Atlanta GA
    Funny cause I did it right the first time and got a piston that fell apart for no aparent reason.
    But yea, I have to take the entire thing apart and re-do another block I have, I will have the other 3 Weisco pistons checked and gone over and start re-rebuilding again.
    Turbo-Wired
    East Cobb
    I would not have the other 3 checked. I would go ahead and ditch them and get a whole new and balanced set together. Getting the three you have, plus a new one, could cause balance issues. Sucks to be in the position you're in, but one of two things must've happened here: You made a mistake, or there was a flaw. If there was a flaw in the product, go back to where you got the product from and see if they're willing to take care of you. If you made a mistake, then I guess it just sucks.
    Alpharetta, Ga
    sounds like the wrist pin wasnt matched to the pistons... i highly doubt now the other 3 "good" pistons have the right wrist pins... ditch the pistons and start again... its hard to do but its the right thing to do...
    The G Spot Hero
    L'ville
    i agree with not-so-jesus-anymore
    Alpharetta, Ga
    ^who is joo?
    The G Spot Hero
