Results 1 to 18 of 18
Thread: Turns over but won't run.
    Default Turns over but won't run.
    Car: 1989 VW Cabriolet
    -Fuel IS getting to the motor
    -NEW- spark plugs, spark plug wires, distributor cap, rotor button, fuel pump, and fuel filter.
    -Battery is up and has a good charge
    -Spark from coil is orange
    -Spark gets to the distributor cap from the coil wire
    -Spark will leave the cap
    -No spark at the end of the plug wires
    -No spark from the plugs
    -(holding these ignition components about a 1/4 inch from the head for a ground)
    The exhaust smells like straight gas. The owner says before the fuel pump, he could spray starter fluid in the intake and it'd run for about 10 seconds. I installed the new parts mentioned and it just turns over sounding like it's trying to start every other revolution, but won't actually run. I transfered the plug wires/distributor cap one by one as to not mess up the firing order.
    I'm lost as to what to try besides a coil, I believe it's a weak coil. Does this sound like a correct diagnosis?
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    hey man i know we didnt hit it off well but give me a chance. id say you most likely right because you should be getting a good healthy blue spark at the plug. what about ignition module,ignitor pack ect...is it getting too much fuel via sticking injectors? i mean im just trin to help, let me know if you get it goin and good luck.
    Augusta Ga
    coil and igniter needs to be replaced .... should run fine .
    93 sol Si
    95 sol S
    95 sol Si
    Quote Originally Posted by 1SOL2NV
    Where's the igniter located on this car? or what is it hooked to?
    I hate this car
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    coil spark should not be orange. blue intense spark is what you are looking for. try a coil.
    Who knows?
    Quote Originally Posted by hondabuilder
    Just put a coil in and it has spark at the spark plugs now, but its still not running. Spark is strong at the spark plug too, no more orange.
    Suffolk, VA
    if you have air (duh) spark and fuel it will run. somethin is missing.
    Who knows?
    theoretically...
    step sticky stephen's Avatar
    sounds like it may have jumped timing, or the belt broke. i'd try to check it with a timing light, or just pull the cover off.
    Augusta Ga
    buy a new car ????? LOL ... .,... OLD GAS maybe .... ? how long did it sit b4 you got it ???? might have water mixed or not enough gas to start engine ? i had a guy who for the life of him could never get his 97 del sol SI to run ... so it sat 6 years without being cranked ..... the gas guage busted on him and after 6 years i added 10$ of gas ... runs like a dream lol ... stupid .. i know ..
    93 sol Si
    95 sol S
    95 sol Si
    lol, well the car isn't mine, just "fixing" it for an old teacher. The gas doesn't smell too old, as stupid as that sounds... I've just smelled gas worse that will still make a car run. I guess I'll go put some gas in it tomorrow though...
    Augusta Ga
    its worth a shot ... my sol ran like **** once when i put fresh gas in it ... but had water in it ... later made my fuel pump go out ..... may i ask why the fuel pump was replaced ? if thats the reason .. then the gas is still in the tank ? u feel me ? OCTANE BOOSTER works great 2 !
    93 sol Si
    95 sol S
    95 sol Si
    Pulled the pump because it just wasn't pumping. But yea, if it has a drain plug like most, I might just go ahead and drain the tank and put some fresh gas in. We'll see! You're definitely getting repped everytime I can rep you if this works. lol
    Augusta Ga
    lol .. it worked for me ... its worth it by this point !!! uve replaced alot of stuff for it NOT to run ... its stupid **** that gets overlooked by many ( including myself) .
    93 sol Si
    95 sol S
    95 sol Si
    yeah, definitely worth a shot.
    Augusta Ga
    keep us posted !
    93 sol Si
    95 sol S
    95 sol Si
    Augusta Ga
    did it work ?!?!?!?!?!??!?!!?!?!?!?
    93 sol Si
    95 sol S
    95 sol Si
    I haven't drained the gas, I talked to the owner and it's apparently only 1 month old and he advised against it. So I checked the firing order and it's all right, next thing is checking timing on the cam gear/balancer...
