Results 1 to 26 of 26
Thread: Car jerks. help please.
    Senior Member G.C's Avatar
    Forgot
    Default Car jerks, tranny problem?. help please.
    1992 prelude si. 5spd h22a.
    recently the car started to jerk every now and then. the fluid is fine and no CEL. it feels like the tranny gets stuck for quick second. it happens in all gears at random times. it feels the worst in 1st gear. the car feels like its not in gear for a quick second,and goes back in gear and jerks really hard. can it be my clutch going bad? I noticed it happens a lot in low speed. 0-30. when i'm in highway it barely jerks and even if it does you can barely feel it.
    :idb:
    한 국
    engine mounts bad (maybe rear)
    Forgot
    Quote Originally Posted by eYezs1ck
    I dont think its the mount. when i did the swap i filled the engine mount with urethane.
    :idb:
    turbos
    is it the engine bogin out?
    TOO BIG
    한 국
    Quote Originally Posted by G.C
    how many did you change out?
    ^ he didn't change them out he filled them with urethane
    Forgot
    filled all of them with urethane. should i drain the fluid and fill them up with Honda manual tranny fluid?
    :idb:
    IA KING
    i read the title and thought you were asking help from car jerks
    Quote Originally Posted by admin
    X2
    I thought he might have been screwed over by one too many mechanics and thought all car people were a$$holes.
    Forgot
    :idb:
    GM Syncromesh
    turbos
    Quote Originally Posted by 87 Turbo II
    X2
    SH*T like that happens to often. I had a mechanic tell me it would take 4 hour and 450 buck to charge my a/c.
    Why cant people be honest
    sorry for the
    TOO BIG
    Forgot
    going to buy the GM synchromesh and see if it helps. i'll let ya know.
    :idb:
    F.A.N.A.T.I.C. primespark22's Avatar
    4real i thought u were calling us car jerks lol
    92 DA9 with a b20 on 8lbs daily
    DALLAS 8-4 1st in the nfc east
    Forgot
    still jerks. feels like the tranny just stops for one second. and engages again.
    :idb:
    step sticky stephen's Avatar
    does it grind a lot when you're trying to put it in gear? also, does the jerking happen in reverse or 5th gear?
    Forgot
    no it doesn't grind. and the jerking happens in all gear except reverse. mostly happens in 1st and 2nd gear.
    :idb:
    honestly, something like this is hard to diagnose without actually being in the car. is it hard to physically put the shifter in 1st or 2nd gear? also, do you smell anything, like a burnt clutch smell after riding for a while??? try riding around for a bit (city speeds), and see if you can smell the clutch burning. i was thinking you might've had bad syncros, but it sounds a little more like a slipping clutch....maybe it keeps engaging/dis-engaging itself causing the car to jerk.
    Forgot
    i drove for 2 hour straight before and i didnt smell anything weird from the car. It start becoming more frequent to jerk now. the jerk feels like when a newb driver doesn't gas enough with the clutch and makes that hard bump. When i'm driving it feels like the gear pops out real quick and goes back in. I think that is making the car Jerk really hard. can that be a bad clutch?
    :idb:
    Augusta Ga
    sounds to me like a burnt clutch .... or a bad throw out bearing .
    93 sol Si
    95 sol S
    95 sol Si
    Woodstock
    Quote Originally Posted by 1SOL2NV
    x2
    douglasville
    x2, exactly what i was thinking.
    Turbo-Wired
    East Cobb
    Have to agree...the fact that it doesn't do it in reverse makes me kinda worried though. If it was the clutch it should do it even in reverse...if you really wanna test it, get some open area, put the car in reverse, let the clutch out all the way and get rolling, then just step on the gas and see if it does anything weird.
    I can't imagine the transmission going bad so that the synchro's on every gear are bad...
    Just a Dude
    Coch town
    My rides doin the same thing,Itll be in first or 2nd gear and it feels like 5th for a couple seconds then it kicks back in after it jerks.
    First thing i thought of was Fuel system.
    Im replacing my Fuel filter and pump,im thinkin its getting choked off.
    Also a burnt clutch would grind.
    Im having to replace my throw out bearing and my 2nd gear synchronizer.
    Augusta Ga
    Quote Originally Posted by driftingkid
    not all times ...
    93 sol Si
    95 sol S
    95 sol Si
    Deuce Deuce BB1_Luda's Avatar
    Do you know how old the clutch is?
