Results 1 to 16 of 16
Thread: having a hard time, still...
    I <3 Fat Chicks Farrow2005's Avatar
    Columbus
    Default having a hard time, still...
    1995 acura integra Rs auto
    still doign that funky thing between idel to 3500 RPM
    tryed TPS, its fine
    check timeing, its set to a T
    plugs, wire, cap, button ignition coil all fine.
    then i catch ear about CPS (camshaft position sensor)
    also what about my ECM
    is that a posibilty.
    any at all have this same problem?
    i would guess its a skipping there is almost no power between idel and 3500, if i give it TOMUCH gas it just goes slow as balls, but if i hold the thottle in the right spot it takes off fine.
    also at idle it just skips/drops idel.
    i have idel set at 700 rpm and TPS is set to 0.45
    i want to get it running right again so i can sell it, maybe keep it and mod it. this is just agrivating the **** out of me.
    my car
    ----edit-----
    almost for got,
    Its fine in the morning. when its cold FINE no problems.
    only after 5 min of driving it does it.
    Quote Originally Posted by admin
    lets compare bush to jesus i mean they are like best friends
    www.street-706.tk
    u test the map sensor
    Columbus
    i think so.
    www.street-706.tk
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    maybe the throttlebody is gunked up. see if all the passages are clean and check the map sensor.
    Columbus
    Not the Map,
    Not the Throttlebody, i have taken and cleaned it off already.
    some one was talling me about some vacume thing in the dizzy?
    so im guessing a new dizzy, though i just installed a new ignition coil...
    i got offered a pretty good trade tonight. if i dont get it fixed my december/jan. im doing it.
    www.street-706.tk
    Augusta Ga
    borrow someones ecu ... make sure its the same ecu as yours currently in the car or one like it ... if it solves the problem then it was your ecu ... thats why i always keep 2 different ecu's around for that reason .
    93 sol Si
    95 sol S
    95 sol Si
    douglasville
    try replacing the iac.
    2.0vtec
    Snellville, GA
    if your idle is surging between idle and 3500 rpm, try looking at the fast idle valve. its located under the throttle body. they do go bad and when they do, it causes the idle to surge. i believe honda did remove them from the later b-series.
    Mahdavi Motorsports
    770-923-1550
    04 S2000 Turbo
    NDRA turbo 6 champions
    Nations fastest auto mkIII Supra
    any cel (very important to point you in right directions if you have any)?
    sounds like tps and map plugs may be swapped (won't nec throw cel). this is why if you take off slow w/ little trottle position the car won't bog, but if you give it a lot of gas it bogs (fuels for a much higher load).
    you said plugs, cap, wires were ok, but are they ngk plugs and honda/ngk wires, cap, rotor? honda's don't like autolites or bosch plugs for some reason. cheap or bling wires will give you problems too.
    JDM TYTE AnthonyF's Avatar
    Quote Originally Posted by mahdsports
    That would affect it all the time. He said when it's cold it's fine.
    Possibly cam shaft sensor...doesnt hurt to try. If the car was in my possession it'd be a lot easier.
    -Ant.
    The Carbon Fibered R6
    Columbus
    there is no idel surge, when im at idel it acts like its going to cut out. like its not getting a spark. when i mean from idel to 3500, as in if i give it to much gas its just boggs down. and take it for ever to go any were. also no CEL.
    ECU would be a good try, but i dont know alot of people around town with an LS ECU..
    i have tryed the the valve under the Throttle body, and the IACV is fine..
    www.street-706.tk
    ^homey, it is spelled "IDLE" fyi.
    I doubt it is your ECU homey. Unless you hooked up your battery backwards, I doubt u fried the ECU.
    -Ant.
    Columbus
    well, its not going to be my problem any more after tonight. trading it for a D16z6 swaped EF hatch.
    www.street-706.tk
    Augusta Ga
    yay ... no problems left ^ ROFL
    93 sol Si
    95 sol S
    95 sol Si
    LaFayette Ga.
    at least try another dizzy. dude im stoked!
    Stone Mountain
    Quote Originally Posted by dohc4.6sc
    x2
    my z31 was running like totaly dyck and i replaced the idle air control, and it runs like a champ
