Results 1 to 11 of 11
Thread: Eagle rods or Scat rods?
    YEAH! bRiAnMcIvIcS's Avatar
    Default Eagle rods or Scat rods?
    Its for a boosted Ls/vtec setup...around 350whp. Ive just found out about scat. haha...Any info is appreciated.
    Don Mon SiRed94's Avatar
    Morrow 30260
    Quote Originally Posted by bRiAnMcIvIcS
    I personally use eagle... but either one will be fine for you... just go with the cheaper choice.... and I believe they both use the same type of steel and the same rod bolts.... and both are reputable just make sure to check your bearing clearances when you put the engine together and you should'nt go wrong
    Stang Mod slostang's Avatar
    Southside
    eagle.
    have some American pride
    Both are identical. They both come from the same place, overseas. The only difference is the company "Eagle, Scat, etc.." finish the products. That goes for the crankshafts as well. The rods are between both manufacturers are about identical, but there is a big difference in the way the crankshafts are finished. Scat finishes a better crankshaft than Eagle.
    Quote Originally Posted by slovic-fcc
    eagle.
    Eagle buys their cores from overseas. There is no "American Pride" there.
    Thanks guys.
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    i went with some h beam rods from a contact of mine for a whopping $200.00 a and ive used em for 4 yrs with no problems and they come in i beam too.
    I never post mrt0mjones's Avatar
    eagle eh? check to make sure they are balanced...
    i've heard of some horror stories....
    everywhere & nowhere
    Since it's a turbo app, I would go w/ the Eagles. Scat rods are considerably lighter --- perfect and more desireable for a N/A setup where you want the lightest moving parts, while the Eagles are a bit heavier duty and theoretically stronger. And BTW - Eagle and Scat do NOT share the same foundry.
    Warner robins ,Ga
    have a machine show check those eagles when u get them i had to balance and bore/gap mine.. to get even the wrist pin in..
    Northwest Georgia
    eagle.
    yeah have some american pride in a chinese made product yay.
    They are however final machined in america i believe.
    go with the eagles, i had no problems with them for a couple of years, they are the biggest bang for the buck out there and hold 600+
