Results 1 to 25 of 25
Thread: First Time Replacing A Rear Quarter Panel
    Wheres the money?
    McDonough
    Default First Time Replacing A Rear Quarter Panel ***UPDATE***
    this is the first time of me doing major body work and would like to know what you guys think....
    Before
    a little work that i have done
    starting to put it back together
    i still have to weld it on and paint the car.
    after welding the quarter panel in.......sorry bout the bad pic
    the old man NAIZBST's Avatar
    looks good so far
    What The Hell
    Kennesaw/Acworth
    yeah looks like it gonna come together nicely once your done
    Duluth, GA
    wow looking good!
    Sweet!
    not bad cant wait to see the final results
    i need ae86 parts canadianrcis's Avatar
    marietta
    damn thats good.
    hachi roku groove
    middle ga
    nice! better you than me!
    that's a great job! Would love to see it finished can't even tell it used to look like that.
    Why didn't you just drill out the seam welds? Looks good though.
    Wheres the money?
    McDonough
    i figured it would be to much work and i didnt want to pull the back glass
    한 국
    your the man
    Quote Originally Posted by tank500999
    First mistake...
    I dont know, I just see things that arent right.
    BMW 750iL
    North Augusta, SC
    Quote Originally Posted by X-Runner
    First mistake...
    At least his wheels are the same color (maybe... can't see them in pic)
    *runs*
    Back to being stock and slow
    Quote Originally Posted by Motivation
    *runs*
    You best run
    BMW 750iL
    good work, thats looks kinda hard to be honest
    LAWRENCEVILLE
    so does the trunk shut?
    Hella stock member!
    Don Mon SiRed94's Avatar
    Morrow 30260
    just be careful when you weld it in not to deform the metal... do several spot welds spaced apart a couple of inches, then go back between those.... if you run a solid bead across it you are gunna have alotta warpage...
    Wheres the money?
    McDonough
    yeah the trunk shut fine i just got to line it up and tack weld it in placw i should have more pic of it tomorrow if im not tired from work tomorrow
    North Augusta, SC
    Quote Originally Posted by SiRed94
    qft... don't rush the weld... too much heat will cause for a lot of headache...
    Wheres the money?
    McDonough
    thanks for the advice
    NANNERPUSS
    Dec 2003
    winder, GA
    usually when i do rears and such, i will always pull and line up the body lines before i cut, it just makes it alot easier when you go to weld, and bolt everything up in the end. except that looks good. if you got any questions i can help you out if you want. i work over at classic collision.
    Wheres the money?
    McDonough
    Quote Originally Posted by rickgiblin
    ok thanks man
    Devin 5thgcelica's Avatar
    snellville
    yeah you already ****ed up..
    you are supposed to pull them to get them straight andthen cut it off.
    but hey. props for trying!
    and do as said before.. do small spot welds.. NO beads. you will warp the piss out of it.
    Wheres the money?
    McDonough
