Thread: B13 sentra.....SR20DE swaps
    14K
    northside
    Default B13 sentra.....SR20DE swaps
    this is a 92 sentra 2dr. XE 5spd with the 1.6L in it right now, my friend wants to know what is all required to make this happen
    *are the SE-R models compared to the same year G20's any different
    can the parts be interchanged
    *big question is what mounts to use, what parts from the 1.6L can be used
    *what kind of engine harness, and other harnesses are required to make this run perfect
    thanx
    It's just a Sentra
    Gwinnett, Georgia
    Came to the wrong place to ask such a big question! Anyways atleast you found one of the few people on this forum you can help you regarding this question.
    1st of all here it's a couple of helpful links:
    http://www.sr20-forum.com/showthread.php?t=2474
    http://www.sr20-forum.com/showthread.php?t=33
    There isn't many parts you can use from the 1.6 motor. You need to get the Engine harness, ECU, Motor, transmission, motor mounts, crossmember, axles and if you are real serious about making it perform like an se-r you need to get rid of the rear drum brakes and se-r sway bars. This is a short list of the main items that you need to make this happen.
    "If you want peace, prepare for war"
    MarJaC RacN Paree4g63's Avatar
    Dirty SOuTH
    Default hmm
    I used to be a b13 sr20de owner myself. Props for having one as well! There are alot of swaps available for the b13,p11 & b14 models. I believe all the Infiniti G20(t) models have the sr20de motor if i'm not mistaken.
    Motors you can swap into a b13/b14 & infiniti g20 chassis are..
    sr20de 2.0 (they have euro motors as well, low & high compression available)
    sr16ve (nissan edition of their vvl(vtec) motor)
    sr20ve (neo vvl 2.0; best motor for N/A route)
    GtiR (Basically like a sr20deT motor; not 100% sure about this one but I've heard you can hit 13's easily with this once accurately installed)
    sr20det (sr20 motor with a t25 turbo kit; bluebird or redtop)
    I've got brothers & cousins who all own b13's/g20's..
    One of them is on here..his sn is Wunquikser; he does all the installs himself; he'll tell you what you'll need. Hope I helped you out.
    North Augusta, SC
    ^^^correct about the G20 having the sr20de motor...
    and x2 on wunquikser... he's helped me with questions that I had on my b13 se-r
    Back to being stock and slow
    It's just a Sentra
    Gwinnett, Georgia
    There are even different versions of the very own N/A SR20DE motor. Highport which you can find in the B13 sentras and NX2k's. There is also the lowport which you find in the 1994 Sentra Se-R, Nissan 200sx se-r, Nissan Sentra SE-L and infiniti G20. People claim there is a slight higher HP differece between the lowport and highport because of the intake manifold design and emissions restrictions.
    The 98+ Nissan Sentra SE-L, newer infiniti G20's and the 00-01 Nissan sentra SE all share the Roller rocker motors which are not the strongest SR20 motor between them all.
    You can also find the UK 10.1 compression motor which it claims to have 150 HP but they are a little harder to find.
    NoRth_SyDe NiSSaNs wunquikser's Avatar
    y not jus find an se-r shell..it would save you alotta time and money..theres a couple guys around the atl area that has some shells for sale..save the xe sentra as a DD..
    if thats not the case then, basically you'll need everything from a se-r..motorwise get a jdm highport and goodluck to ya and ya friend and have fun..
    92 sentra ve'd
    COME GET SOME!! 191whp 150wtq N/A
    One Curve At A Time
    I sold my 94 LE for 1800 and bought a 91 SE-R, You can get a SE-R fairly cheap. If you are willing to put in the money to swap, do a VE, those things are nasty
    97 DX Civic w/ H22 FS
