Results 1 to 13 of 13
Thread: bad bearings
    F.A.N.A.T.I.C. primespark22's Avatar
    Default bad bearings
    will bad bearings cause the front tires to have some play?or could it be something else?please people i need help my car hasnt moved in 2 weeks i need to get it going today!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!reps will be given
    yes it can, also tie rod ends can too
    jack the car up wheels off the ground..if it has play side to side up an down...most likely your bearings are done needs fixing NOW
    If it only moves from side to side with lots of play but not moving an suspension parts, take a big pair of pliers an grab the tie rod end an see if it has play an if it does then replace it...when i mean play its all moving in the boot very easy ...If you dont know how to do this, go to any shop an most of them might look at it , might charge you alittle DIAG fee but might be worth you time if your not able to do this.Best of luck Joshua
    alright mr. joshua good advice thank u, ill give u rep for that but i dont think it could be the tie rod end cuz they just got changed with a brand new rack and pinion
    Most racks dont come with tie rod ends...Unless they install some new ones when they bought the rack an installed it...But remember every part is MAN made anything can happen...BTW what kinda car are we talking about
    Quote Originally Posted by primespark22
    a 97 ej6 or civic dx coupe lol
    most likely its the bearings!And those are Pressed in so you would have to press the hub off an press the bearing out, an re install an press it all back in...BTW if you replace all 4 wheel studs while your there.You will thank me later if you do!
    Most shops charges from 100-150 labor/parts to do this!
    You must spread some Reputation around before giving it to JoshuaASE again.sorry dude but thanx for the advice if i run into anymore problems i might just hit u up lol
    No problem hope I helped! Joshua!
    oh yeah one last thing it took a month and a half for my camber kit to come in so i drove around with a major unalignment that could have made the bearing go bad right?
    well i am not going to say yes, But with your miles I am sure its 150+,ooo miles
    But it can put a strain on them
    no im at 120,000miles on my car
    close enough lol!
