Results 1 to 40 of 43
Thread: most reliable swap?
    stockbridge ga
    Thumbs down most reliable swap?
    whats the most reliable swap for an ej2?
    i just rebuilt a d15b and 3 days after the first crank i dropped a valve and jacked the sleeve up
    what the most reliable B swap?
    kangarooster meadows
    Any B swap will be reliable if it's done correctly.
    Senior Member boosted b's Avatar
    x2
    Quote Originally Posted by alpine_xj
    Lsu tigers going # 1 again
    Middle, Ga
    www.TigerJapanese.com Go with a JDM B20b..They have good prices on motors and tranny's of all kinds! They have a good B20b right at $600 and a B18b right at $800.
    "Damn, Its Tyler"
    RaceReadyDevelopments
    Marietta, GA
    b series ftw. can't go wrong with any of them really. it boils down to what your goal is on this car though. are you trying to build a beast or a daily driver?
    stockbridge ga
    Quote Originally Posted by integra82786
    just a tuned daily driver since i drive from stockbridge to chamblee everyday and i play show almost everyweekend
    stockbridge ga
    Quote Originally Posted by Fast-Tech
    im lookin for a simple drop in and go for the time being
    but good lookin out
    even tho TJ.com is notorious for having seized motors and i know alot of guy who got the wrong motor
    Southside of The Jungle
    Do it cheap do it Twice!
    stockbridge ga
    not cheap just basic so that i dont have to call out 3 different tegs and 2 different civic when i lookin for replacement parts at autozone
    Newnan
    d15b7 for me has been the most reliable honda motor so far...if you know what you are doing you shouldn't have a problem with them
    North Augusta, SC
    All depends on how it is done... Any motor can really be dependable if done right. But doing it right=more money... so what is the budget?
    Back to being stock and slow
    stockbridge ga
    Quote Originally Posted by Motivation
    4-5k
    i understand what all going into to doing a swap and all i have everything need to pull motors too
    im been lookin on jsamotors.com and they have a diagram for swaps and everything.
    i think im just gonna do a basic b16a2
    1.5T AnTi-PooN's Avatar
    L'villE
    Quote Originally Posted by gar9854
    lol story of my life...
    just grab a b16 like everyone else
    tito racing titoeg16psi's Avatar
    ls/vtec
    Out in the Boonies
    any motor is reliable, depending on how you build it and if you know how to put it in correctly.
    Duluth, GA
    Quote Originally Posted by titoeg16psi
    ls/vtec
    yeah because that's reliable
    clayton county
    a stock single cam non vtec....
    not trashing you but if you or whomever rebuilt the motor did it right it wouldnt have dropped a valve. i got a friend with a D15B vtec and its the most reliable motor out of everyone that he hangs with lols
    I give out reps....
    NW ATL
    ive heard bad things about tigerjapanese... cant go wrong with hmotorsonline.com
    E46 M3 Z0_o6's Avatar
    Suffolk, VA
    Quote Originally Posted by Captain-Obvious
    MYTH. ls/vtec is as reliable as you mkae it.
    Who knows?
    stockbridge ga
    everything is rusted out when u get a motor from hmotors
    stockbridge ga
    well idk what went wrong we check and rechecked the valves b4 we even turned it over...
    it ran smooth as glass for a few days and everything i just cranked it up on day and its just popped
    the previous owner sprayed it like crazy
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    Hmotors is the best engine supplier in the states
    Hiawassee, GA
    This man knows what hes talking about.
    -Zach-
    1987 Toyota Pickup - Toy
    stockbridge ga
    well ive seen two longblocks come from hmotors and crap was ALL FvCKED up
    but thats just what i saw
    YEAH! bRiAnMcIvIcS's Avatar
    www.hmotorsonline.com
    Go with the B18C5(OEM All motor perfection...haha).
    stockbridge ga
    Quote Originally Posted by bRiAnMcIvIcS
    did u not see the 4-5k budget?
    and i'd rather stay on the 4k side
    Norcross
    b16 would be ur best bet.. not too expensive.. cheap and reliable.. not to mention decent speed
    gwinnett
    b20 ftw.
    Quote Originally Posted by JDMirza
    b20 ftw.
    x2 FTMFW!!!
    Georgia Muscle twinj's Avatar
    Da "A" Niccuh
    Indeed. Thats where I got my motor and tranny, I had 0 problems out of both.
    FUK IT! bowdown201's Avatar
    Next Door
    anythings reliable if you do it right and take care of it. b20 ftw tho..cheap, reliable and has good power
    stockbridge ga
    how easy of a swap of a b20b or b20z is it into and ej?
    and should i go ahead and throw on a b16 trans?
    Just get a jdm b20b 99-00 spec...cheap and easy swap.They are rated at 146 hp and 133 ft-lbs torque. I would use a gsr tranny.
    I'd say a K20 EK would be the most reliable. Unless you could get a Fit's 1.5L in an EG or CRX.
    Banned tippatone's Avatar
    College Park
    Thats where i got my B20B from, still running hard i must say
    I would say gsr, or type r depending on the money you are looking to spend. Also try Hmotorsonline, you get what you pay for, and I have gotten many motors from them all flawless. They even take certain sensors off to prevent damage during shipment, and if something is screwed up they will send you a new one.
    Tiger Jap is hit or miss, I have seen motors run great, then I have seen them not run at all or smoke like a freight train.
    NAD auto local is a good place also.
    stockbridge ga
    but once again how hard or easy is it to b20 swap an EJ?
    North Augusta, SC
    I wouldn't think it would be much different than doing a B18 swap.
    stockbridge ga
    so mounts and jumper harness
    Newnan
    and axles edit, don't do a jumper harness just get a b-series harness and hook it up to a b20 ecu, not sure if d-series has all the right hook ups for b-series, but safe to say you will have to get a b20 or ls ecu
