Results 1 to 18 of 18
Thread: 98 Prelude
    IA's Tire Girl
    Stockbridge
    Default 98 Prelude
    Why do my cam seals continue to leak after being replaced twice??
    1998 Honda Prelude Base
    2009 Honda Civic Sedan Si
    IA's Tire Girl
    Stockbridge
    Can someone help me out here please???
    i just changed on my integra....use the black silicone.....worked for me....just make sure to wipe of the excess....i couldnt tell you the reasoning behind it though
    EJ1....sohc ride out
    IA's Tire Girl
    Stockbridge
    doesnt help me much, but thanks anyway...
    IA's Pedo-cord tdurr's Avatar
    Fayco
    who replaced em? (jw)
    (oh snap post two foady!!)
    T-durr
    What did you use? OEM? I recommend aftermarket one with double or triple o ring. STR, BDL, BLOX all make one for 5th gen prelude. I replaced mine with Blox triple o ring seal about 20k mi ago and it stopped the leak immediately. Check Ebay, or Nopi!
    Its notorious for doing that. All H22 for Prelude all do that. That's why everyone in the Prelude community replaces them with the Aftermarket. Like go look up skunk2 or go on ebay and look for h22 cam seal. Hope you have good luck.
    get an aluminum cam plug w/ teh orings as was mentioned..u dont even need any kind of sealant..install and roll
    also if you havent changed out your tbelt I recommend doing so immediately. There's also notorious for failing and ruining your engine.
    IA's Tire Girl
    Stockbridge
    Timing was done when the first set of seals was replaced.....I took it to the shop today and turns out it isnt the cam seals again....its the oil pan...so they ordered a new one for me kept my car and put me in a rental and said BE GONE BIATCH........lol....
    HOW IS UR OIL PAN? WHERE WAS IT LEAKING FROM BEFORE U HAD UR SEALS DONE?
    IA's Tire Girl
    Stockbridge
    Well the very first leak was coming from the drain plug, so they re-threaded the drain plug and sent me on my way...shortly after that it started leaking elsewhere (cam seals). While they had it all taken apart they did the timing and waterpump . I picked the car up a few days later...after driving it for a day it started to sound like it had a supercharger...lol...so I took it back and there again it was those cam seals....it hasnt leaked since which was about 2 months ago up until yesterday I noticed opil in the driveway
    In the land of the slow cars
    Just blow it up...
    North Augusta, SC
    What shop you take it to?
    Back to being stock and slow
    IA's Tire Girl
    Stockbridge
    Just SHUT UP......
    Quote Originally Posted by stillaneon
    Just blow it up...
    Quote Originally Posted by 98ludegirl
    Just SHUT UP......
    Done
    JDM TYTE AnthonyF's Avatar
    When you pull your cam seal out, make sure you didnt gouge the metal. The seal wont be able to seal in that area. Also, when you remove it, clean all the excess material and make sure it is nice and clean. It's not a bad idea to add a little grease around the lip to let it slide in easier and not get cocked crooked.
    -Ant.
    The Carbon Fibered R6
    ALSO-make sure you are getting OEM Honda seals. At our shop we will use after market but for Hondas we only use Honda OEM b/c others never fit right.
    -Ant.
