Results 1 to 40 of 55
Thread: Audio experts needed please....
    JDM TYTE AnthonyF's Avatar
    Default Audio experts needed please....
    Well, lets start off with my setup. I am running the factory head unit, I have one of those little boxes from circuit city so I can wire up a sub/amp, I have a kenwood 1000w amp and 2 L7 Kickers. I have wired them up in many different variations. But I still get the same problem. Now It is being more common. The subs will hit very hard then dim down and stay that way for awhile. Every now and then it'll go back to normal and pound once or twice, then fade away. It used to only happen when I pushed them very hard, but now it is all the time. Any ideas? I really appreciate the help.
    -Ant.
    The Carbon Fibered R6
    **H.I.D KING** Nitro's Avatar
    STMN GA
    hit Kevin up....... expert at *Platinum Audio* 770-596-0452 tell him u my homieeeeeeee
    Clear you PMs man. I can help you fix this also.
    DBlock
    tha ville
    sounds like voice coil issues!!!!!.......hope u arent hearing words through your speakers!!!!! ........1
    No words though the speakers. I wired the subs up in a series yesterday which prob made it worse. But when I had the amp wired up for the 2 channel option and the subs wired up normally, I pulled out one of the male RCA connectors and the **** POUNDED harder than ever. I dunno why....I hate audio. I never understand it.
    -Ant.
    DBlock
    tha ville
    hahahahhha i know what your problem is!!!!!!! ...........haaaahhahhaa.......did u clear your pm's????
    Fack it!!!!! ill tell u
    seems like u have the wires reversed on the back of the speaker........all u gotta do is simply swap out your pos and neg wires on one speaker......bet it will hit great!!!!!.......1
    no, the speakers are wired up correctly. I tried to wire up the subs in a series. taking the + from one running it to the - of the other, while that + wire ran to the bridged + of the amp and the other speaker's - was wired to the amp in the bridged - position. Get what I am saying? EVen when it WAS wired up the normal way, with the 2 channel option, each channel to each speaker, it would cut off and barely hit. Then it would come back on, then off, etc....
    -Ant.
    DBlock
    tha ville
    -Ant.
    wow i never wired anything with the neg and pos together!!!.........im thinking u might wanna bring it to a shop cuz i dont wanna hear no bad news about the truck!!!!! .....1
    ^like what? What would happen? Not like it is going to blow up. You've never wired anything in series? When your running 4 ohm subs or when ya gots 4 terminals on ur sub, you run the + to the -
    -Ant.
    DBlock
    tha ville
    -Ant.
    yea ant just personal prefference but i always run one sub because its easier......ran 2 twelves in the old neon and didnt like it!!!!....
    when i had my 2 12s in i had the same problem cuz once one starts goin bad it makes the whole thing sound like shyt!!! with that being said u have L7's so u are good!!! those are like the best speaker to get!!! i have an L5!!!:goodjoB:
    if your shyt keeps cutting off and stuff its prolly doin the protect mode thing!!!.....which is never good on an amp!!!!! just be careful ive had my fair share of amps blow up!!!! not kool!!!! ........1
    I got 2 L7 solobarics....for FREE!!!
    It might be. I paid 100 bucks for this amp brand new at pendergrass flea market. I might just need to upgrade to something stronger.
    -Ant.
    DBlock
    tha ville
    -Ant.
    man ok .....so tell me something!!! what size fuses are on the side of the amp???? ......
    i shoulda asked that earlier!!!!!.................1
    anthony..gimme some L7s...PS i hope u fix ur issue
    blank
    nowhere
    shut up
    DBlock
    tha ville
    shut up
    ...tsk tsk.....play nice guys .......1
    bucky wildin again
    Bucky is whoring up my thread wit dat nonsense. lol
    I have a 40 amp fuse in the amp and I believe a 40-60amp for the amp power wire.
    -Ant.
    blank
    nowhere
    you dont need a fuse. use a pennie
    DBlock
    tha ville
    -Ant.
    amp X voltage = wattage!!!!!..........so a 40amp x 12v = 480 watts..............u need to upgrade those L7's are not liking 500 watts!!! .....that could be your problem!!!!!.....1
    lol. No! Why you being so mean?
    I dont need to upgrade subs, I need to upgrade fueses, is that what u are trying to say?
    -Ant.
    i think he means upgrade your amp
    ^it's cus you black folk speak on a different frequency and understand each other. lol
    -Ant.
    DBlock
    tha ville
    YEA DO NOT PUT BIGGER FUSES IN THAT AMP UNLESS U WANNA BLOW THE TRUCK UP!!!!!! ((((no pun intended))).....
    my L5 calls for a minimun of 500 watts so i gotta class D amp 1000watts........has 2 30A fuses!!!.........
    u gonna need to upgrade ya amp man ............1
    02 WRX patrick4588's Avatar
    warner robins
    that amp is not nearly enough for those subs. are those dual 2 ohm vc or dual 4 ohm vc? i personally would get a mono block instead of a 2 channel amp. anyway, if they are dual 2ohm, wire them in series and you will get a 2ohm load. if they are dual 4ohm, wire them in parallel and get a 1ohm load. make sure to get an amp that is 1ohm stable if you go that route. you will need an amp that can run about 1000w rms to power them. gl
    GCO Member
    NRA Member
    DBlock
    tha ville
    damn he summed me up in one post ........1
    -Ant.
    FAWK U ROCKY
    they are dual 4 ohm subs. I guess I will have to upgrade. Amps are just so damn expensive.
    -Ant.
    i'm suprised u didnt know u had to reach at least the minimum (rms) wattage in order to satisfy your sub...but u dont know nothing about satisfying do you...always come up short...italian bamma
    ^It's not that, why is the amp cutting out though? I can see if it maxes out but why cut off? I hate audio sh*t.
    -Ant.
    the sub requires 500+ just to get it started...as stated by BB50..ur giving it 480watts (i imagine thats your amps full capacity) there for you are running the amp overtime causing it to cut out.
    wats the specs on that amp u have pushing BOTH L7s?
    -Ant.
    -Ant.
    double tee eff double post motherfletcher...quit it
    warner robins
    you could go with this amp and run each sub to its own channel and it would power them perfectly. it runs 500w rms @ 2ohms per channel. also, mtx amps always underrate their amps, so its probably closer to 600. pretty good price too.... http://www.buy.com/retail/product.as...36&dcaid=17902
    GCO Member
    NRA Member
    DBlock
    tha ville
    yea man look into the kicker amps 2!!!! they make the L7's sound the best!!!!!!.....1
    DBlock
    tha ville
    reps for u dude!!!!! i tried to explain to someone about MTX underating their amps and got looked at funny!!!!! .....1
    amirite about old fosgate amps being underrated too? like i have a 260sd says like 60watts or some nonsense...but i seen it beat up a12...
    warner robins
    i have a thunder elite 801d and its rated at 800w rms @ 2 ohms. birth sheet said 965 @ 2ohms.
    GCO Member
    NRA Member
    they are not underrating their amps, they are saying it can and WILL hold 500 continuous watts w/o losing power
    -Ant.
    well...u have issues...
    Greene/Athens
    i think he's saying you need to upgrade that amp. your starving the l7's lol. i had the kenwood 920 and i couldn't keep a fuse in it unless i wired it in a series. Had nothin but problems out of it when i hooked it up to a sub with a high rms. like the titanium eclipse and the eye candy audiopipes. *edit* yea my bad i posted after readin the 1st page but not the second. oops lol
    Hiawassee, GA
    Anthony hit me up, I got the perfect amp for those 2 subs.
    -Zach-
    1987 Toyota Pickup - Toy
