Results 1 to 10 of 10
Thread: B20 turbo setup question???
    E46_ZSP rude_lude911's Avatar
    Macon, Georgia, United States
    Default B20 turbo setup question???
    Is a B20b turbo setup with a GSR tranny a good setup? What are my pros and what are my cons? And if so what is the best motor build setup to go with?
    Southern Speed
    Macon
    Wrong section, and yes
    Stang Mod slostang's Avatar
    Southside
    hell NO.
    b20 has some weak ass sleves. they can take 8 psi MAX reliably. get basically any motor besides a b20.
    Senior Member G.C's Avatar
    Forgot
    ^ he is right. b20 is not for turbo.
    :idb:
    YEAH! bRiAnMcIvIcS's Avatar
    Just resleeve the block. Golden Eagle Mfg.
    the county
    b20 is best left NA. better have it sleeved if you do boost though or you'll be buying a another block anyway. you might be better off boring over a ls with a block guard. probably save you some $$$ and won't have to deal with yanking the motor out of you car after you put it in.
    Certified Gearhead thirdgenss's Avatar
    Columbia SC
    we have a b20 turbo coupe here in columbia that is a beast. easily an 11sec car if not faster
    Don Mon SiRed94's Avatar
    Morrow 30260
    haha wtf is this, the little IA porn bot and sh!t...^^^
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    obviously some peeps on here dont know **** when it comes to b20s. i ve installed 8 b20bs including my own. they all push 250-275ish on 8-10 psi all day every day drivers no probs in 4 + years. just gotta find that sweet spot. no b20z or high compression crv motors as high compression b20 with a small cc chamber vtec head is even higher still then add boost ontop of that... thats what causes higher cylinder pressures and probs with those particular sleeves...stick with a 8:8:1 compression b20b and remember to open up the intake valve pockets on th pistons slightly as the v tec valves and lift in vtec are bigger and higher. and swap in the stock rod bolts for some arps so you can get a reliable 8000 rpms out of em...got almost 60,000 boosted miles on my b20. good luck.
