Thread: greddy turbo
    Default greddy turbo
    OK i just bought an greddy turbo kit from JDMmadness. i was wondering if somene could tell me what the open hole is in the turbo picture below.
    that turbo is oil and water cooled. That hole is a water passage.
    Don Mon SiRed94's Avatar
    Morrow 30260
    Quote Originally Posted by mp82
    Si...
    Default hey
    so was it an good buy?an can i use it as an oil line
    Depends on how much you pay for it and the conidition of it. I would use oil and water cooled. If oil only chances are you might burn up the bearing. I wouldn't recommend using the water passage for oil where it suppose to be for water. There is already 2 holes for oil, and 2 holes for water.
    Default oh
    ok so how do i use both oil an water?could anyone please tell me how to mix water an oil on this turbo
    water can be tap at throttle body coolant lines or anywhere with coolant
    Oil: back of block where oil sending unit is with a tee fitting. Oil drain from turbo to oil pan.
    Default hey
    i know how to do the oil lines but i just dont understand the oil to water an how i would tap it off
    It's two different passages. Oil is separate from water. Use a 3 way tee tap. Use one coolant line for feed and the other line for drain. Think of this. When you have just a oil cool turbo, oil goes in and out. Now they just added water, it does the samething in and out.
    Default ok
    to me it just seems like the water is gonna get in the oil pan lol
    lol don't mix the line up
    IA MEMBER turbob20's Avatar
    LaFayette Ga.
    find the existing throttlebody coolant line take it off at both ends run a long line to your turbo wich will be the bigger 2 passages that are the same size across from each other then as it goes through the turbo cooling the intenals but not in the same part as the oil will flow it will exit across fromm where it goes into the turbo and run it back to where the other side of the coolant line went on the throttle body. as for the oil tee off the sending unit on the back of the block. run it to the smallest inlet on the turbo on the top. then fix a drain in the bottom back into oil pan. REMEMBER OIL GOES IN SMALL INLET IN TOP OUT BOTTOM, THEN WATTER GOES IN SIDE OUT OTHER SIDE. THE WATER AND OIL PASSAGES IN TURBO IS LIKE AN ENGINE BLOCK MADE INTERNALLY BUT KEPT SEPERATE BY THE OIL AND WATER PASSAGES.
