Results 1 to 3 of 3
Thread: Possible engine build in the works. Advice please. (GSR build)
    SPACE WEATHER!
    Cecil
    Default Possible engine build in the works. Advice please. (GSR build)
    This weekend I've been really thinking about rebuilding the engine in my GSR. I'd like to do it because it has 165k miles on it and feels lacking in power. It runs great, don't get me wrong, but I just like having peace of mind and a little more performance is always fun. If I decide to go through with it here is what I was thinking:
    Bore block to 81.5mm
    RS Machines ITR pistons (should yield close to 11.4:1 compression)
    ACL bearing set
    ARP head studs/rod bolts
    OEM Honda gasket kit/timing tensioner/water pump/oil pump
    Gates timing belt
    I'll be using my factory GSR head of course. I have a friend that owns a machine shop that will be doing all the block work and will check over my cylinder head for me as well. I'll do all the disassembly and assembly myself.
    First and foremost, will 11.4:1 compression be too much for a reliable semi-DD? (I have lots of cars to drive, so this won't be driven everyday) Will the engine perform well with the factory GSR head and cams? I want to upgrade valvetrain/cams sometime, but I was hoping to put it off a bit. What sort of power could I possibly expect with this setup? (keeping in mind I have an ITR header, 90mm exhaust, blox intake mani)
    I know a lot of people do the poor man's ITR with really good results but I can't seem to find many people who have done this with just a GSR head and without upgrading the head/cam. I posted on Honda-tech but my thread didn't get any replies then disappeared in the sea of threads, haha. Any input is appreciated.
    Tom
    SPACE WEATHER!
    Cecil
    I just got to the bottom of Kidd's engine build thread and noticed that he'd already built one of these almost like what I want. I guess that just about answers my questions.
    2) Username: DA_UNKNOWN
    Engine: GSR B18C1
    Block: OEM ITR Pistons
    Head: Skunk2 Digital CNC Ported Head
    Camshafts: Skunk2 Pro1s
    Valvetrain: Skunk2 Pro Series Springs and Retainers/Skunk2 Valves
    Header: RMF Header
    Intake manifold: Skunk2 Pro Series
    Throttle Body: 70mm Skunk2 Pro Series
    Engine Output: 202whp/137TQ
    Tom
    M.O.B inutero93's Avatar
    valdosta ga
    the car is not slow your just slow hahahahaha...
