- CEL 19 need help please
ok so my 93 civic threw the code 19 which is automatic lock up/ basically throwing my car into safety mode and giving less fuel for some reason(I think). it is a 5-speed so it has nothing to do with the trans. before it threw the code it would run like crap until high rpms then it would burst back to feeling normal, then it threw the code and I cant move the car w/o it bogging down and dying. its not the injectors/plugs/plug wires or cap from what I know. I can only think its the o2 sensor or fuel pump. also how can I reset the ecu to take off the code(already took battery out and disconnected it and no luck. just threw code 41 as well, checking that code now, I didn't wait long enough for both codes to pop
Crash
- Rep Power
- 20
Code 41 - Primary Oxygen Sensor/ Heater Circuit Malfunction
Code 19 - Defective circuit or unplugged / defective solenoid valve
1993 Honda Civic EX
1993 Acura Integra
1998 DB7 Integra
1989 Toyota Supra
1993 Toyota Supra
Crash
- Rep Power
- 20
1993 Honda Civic EX
1993 Acura Integra
1998 DB7 Integra
1989 Toyota Supra
1993 Toyota Supra
thanks man, fixed it, it was actually code 41(fuel system) and all the injectors have little filters in them that I checked, and ALL of them were clogged full of shiit, fuel filter FTL!
Crash
- Rep Power
- 20
ah, well good shot anyways. well its fixed and thats what matters!
1993 Honda Civic EX
1993 Acura Integra
1998 DB7 Integra
1989 Toyota Supra
1993 Toyota Supra
- You may not post replies
- You may not edit your posts
Forum Rules
