Results 1 to 28 of 28
Thread: BNIB Onkyo TX-SR605
    professional student
    Default BNIB Onkyo TX-SR605
    I purchased this directly from Onkyo 3 months ago and never got around to using it. It's only been taken out of the box and placed in spare bedroom and powered up once to make sure it was operational.
    This unit is not a refurb from onkyo, it was purchased brand new from onkyo directly and comes with remote, setup/tuning mic, and all manuals/accessories.
    $350 + shipping
    Specs on the unit
    Amplifier Section
    Power Output - Front L/R 90 W + 90 W (8 ohms, 20 Hz–20 kHz,
    0.08%, 2 channels driven, FTC)
    105 W + 105 W (8 ohms, 1 kHz, 0.7%,
    110 W + 110 W (6 ohms, 1 kHz, 0.1%,
    2 channels driven, FTC) Center 90 W (8 ohms, 20 Hz–20 kHz, 0.08%,
    105 W (8 ohms, 1 kHz, 0.7%, 2 channels
    driven, FTC)
    110 W (6 ohms, 1 kHz, 0.1%, 2 channels
    driven, FTC) Surround L/R 90 W + 90 W (8 ohms, 20 Hz–20 kHz,
    2 channels driven, FTC) Surround Back L/R 90 W + 90 W (8 ohms, 20 Hz–20 kHz,
    2 channels driven, FTC) Dynamic Power 210 W (3 ohms, 1 ch)
    180 W (4 ohms, 1 ch)
    110 W (8 ohms, 1 ch) THD (Total Harmonic Distortion) 0.08% (Rated power) Damping Factor 60 (Front, 1 kHz, 8 ohms) Input Sensitivity and Impedance 200 mV/47 k-ohms (Line) Output Level and Impedance 200 mV/470 ohms (Rec out) Phono Overload - Frequency Response 5 Hz–100 kHz/+1 dB, -3 dB (Direct mode) Tone Control ±10 dB, 50 Hz (Bass)
    ±10 dB, 20 kHz (Treble) Signal-to-Noise Ratio 100 dB (Line, IHF-A) Speaker Impedance 6 ohms–16 ohms
    Video Section
    Input Sensitivity/Output Level and Impedance - Video 1 Vp-p/75 ohms (Component and S-Video Y)
    0.7 Vp-p/75 ohms (Component PB/CB, PR/CR)
    0.28 Vp-p/75 ohms (S-Video C)
    1 Vp-p/75 ohms (Composite) Component Video Frequency Response 5 Hz–50 MHz
    Tuner Section
    Tuning Frequency Range - FM 87.5 MHz–107.9 MHz AM 530 kHz–1,710 kHz FM/AM Preset Memory 40 stations
    General
    Power Supply AC 120 V, 60 Hz Power Consumption 6.5 A Dimensions (W x H x D) 17 1/8" x 6 7/8" x 14 13/16"
    (435 x 174 x 377 mm) Weight 25.1 lbs. (11.4 kg)
    Product Features
    Amplifier
    # Channels 7 Power (8ohms 20-20kHz 0.08%) /Ch 90W Power (8ohms 20-20kHz 0.05%) /Ch - Power (8ohms 1kHz 0.7%) /Ch - THX Certified - Continuous 6ohms Rated Certified 4ohms performance - High Instantaneous Current Capability 36A Amplifier Frequency Response 5Hz-100kHz S/N Ratio (LINE IN) 106dB All Discrete Circuitry Absolute Ground Plate Dual PUSH-PULL Design - Independent Block Construction (Amp/Preprocessor) - Toroidal Transformer - Independent Power Supply - Optimum Gain Volume Linear Optimum Gain Volume - Non-Scaling Configuration Bi-amp Capability For Front BTL Capability For Front -
    Processing
    DOLBY Decoder DD Plus, TrueHD DTS Decoder DTS-HD Master Audio Neural Surround THX Processing Mode - DSD Processing/Direct Mode - / - Direct/Pure Mode / - Music Optimizer - Audyssey Dynamic EQ - 192K/24 Bit DACs VLSC - DSP Type / QTY 32 BIT Adjustable Crossover 40/50/60/80/100/120/150/200Hz Independent Crossover (LR, C, SR, SB) AV Sync Accurate Speaker Distance Setting Multi-Band Speaker EQ 5 Band
    Connectivity
    Audio I/O 7 / 2 Balanced Audio Output - Balanced Audio Input - Phono Input - Digital Audio IN (OPT/COAX) 3 / 2 Digital Audio OUT (OPT/COAX) - Composite I/O 5 / 1 S-Video I/O 5 / 1 Front-Panel A/V L / R / V / S Front-Panel Optical Component Video / Bandwidth 3 / 1 / 50MHz HDMI I/O 2 / 1 HDMI Version V1.3 Repeater HDMI Bandwidth 1080p HDMI Deep Color Capable (36bit) Component Video Upconversion Analog to HDMI Upconversion 480i to 480p Processing (DCDi) 1080i Upscaling - 1080p Upscaling - Multi-Channel Input 7.1 Surround Pre-Outs SUB Speaker A/+B - Powered Zone2 Zone 2 Line Out Zone 2 Video Out - Zone 3 Line Out - iPod Ready (DS-A2x, DS-A2, DS-A1) Built-in HD Radio Tuner - XM Radio Ready SIRIUS Radio Ready
    Integration Access
    RS-232 - IR Input - Ethernet - ONKYO-RI System Control 12V Trigger -
    Miscellaneous
    Pre-Pro/Learning Remote / - Back-Lit Remote - Glossy Black finished Remote - Simple Remote to change input & mode - Color-Coded Speaker Terminals Auto Speaker Calibration W/Mic. (Audyssey 2EQ) OSD Out Input Name Edit - Permanent Memory Storage Solid Aluminum Front Detachable AC Cord - Warranty 2 YEARS
    Banned BOBA-GA-NUSH's Avatar
    METRO AREA
    Done
    pics obviously don't do it justice. It is BRAND NEW and in MINT MINT MINT condition
    Certified Gearhead 94b20gsr's Avatar
    This receiver is awesome, it's what I'm using for my setup.
    yeah i've played with a couple of them and that's why I picked it up because it really can't be beat for its price range, but unfortunately i'm doing other things at the moment and can't complete my surround sound
    bump!
    bump!
    bump!
    bump!
    make some offers, i really need this thing gone asap!
    this thing looks very promising...
    and funny part is..
    http://www.ecost.com/detail.aspx?edp...1&source=K3736
    also there are some spec on it so if anyone wants to know anything about the product.. there you go.
    gl with Sale...
    I said i'm taking offers, and if you want to get it from the website be my guest. You can pick my receiver up tonight, but in order to get that one tomorrow you would have to pay $65 in shipping.
    Don't come in my for sale thread posting lower prices. You don't like it, stay the h e l l out of my thread
    and if you want that receiver, there is only one left at that price
    not bad
    need it gone so someone buy it lol
    you say it's only been powered up to see if it works, yet it looks pretty well used under that motorola box. lol
    I put it under the motorola box for the pictures because I was afraid it would crush the box if I put it on top since the 605 is so heavy.
    Trust me when I say this thing has literally only been plugged up and powered on one time. The inputs/outputs have never been connected/touched/moved, I don't even think i've turned the rotary volume knob because not one speaker has ever been hooked up to this thing.
    If someone buys it and can somehow prove it has been used or is not in perfect brand new working order, I will give them their money back
    specs updated
    buy this now...really need it gone...located in kennesaw off barrett pkwy
    NOT THE SAME EXACT THING
    If you read in the fine print it specifically states it is :
    Product condition: Onkyo Factory Reconditioned
    So once again, this item is brand new and not REFURBISHED
    if anyone has done any research on these things, the refurbs have problems with feedback through the hdmi inputs/outputs and the speaker connections.
    So nice try and thanks for showing people that REFURBS are right around the price i'm asking for an unused perfect condition unit purchased DIRECTLY from Onkyo
    bump!
    ttt
    ttt make some offers people!
    post up some offers, I really need this thing gone!
    ///M :) wannab20hatch's Avatar
    Gainesville
    got the receipt to prove its original? original box? thinking of upgrading my system.
    ygpm
    SOLD to a good home on diymobileaudio.com
