Results 1 to 14 of 14
Thread: I CAN'T SEE! no headlights..
    lost 3'' in 3 hrs!!! 1moreaccord's Avatar
    l'ville
    Default I CAN'T SEE! no headlights..
    So a few weeks ago my right headlight went out.. I thought it was burned so i looked at it.. didn't look burnt but u can never tell jus by lookin.. Anyways I have no $ so i jus put it back.. A few days later it came back on.. not burned out.. It would go off and on randomly..
    Last week BOTH headlights went out.. I smacked one and it came back on.. now they r both out for good.. so they aren't burnt out.. wut r they?
    Anyone know wut I should check? Or wut I can do to get them workin again? wiring? shorts? fuses? j/w if its happened to you.. lemme know..(will reward with rep :P )
    Whore for the AWD LordZed's Avatar
    Marietta, GA
    Replace both of the lights first there buddy. Sometimes the filliment gets loose and will still make random contact with the post. Try that first.
    In the land of the slow cars
    And be sure to check fuses
    Marietta, GA
    They would have gone out at the same time if it were a fuse it seems. But worth checking as well.
    l'ville
    ahhhh touchee.. shoulda changed em out 1st.. i'll try thx..
    Augusta Ga
    Quote Originally Posted by LordZed
    no they wouldnt ... had a 94 civic 4 door do this same **** to me the other day ... replaced the fuse when only 1 headlight was working and without replacing the bulb both started working again ! ... Check fuses !
    EDIT: check the fuses with a voltmeter on both posts of the fuse or with a voltage light ... ive seen some fuses not work and not blown and it wouldnt let the right amount of current out ...
    93 sol Si
    95 sol S
    95 sol Si
    Yeah its a 4 door
    Not neccessarily....my accord has individual fuses for each side headlight (right / left). possibly the wrong watt bulb, resulting in your headlight harness melting in some spot grounding out??? Maybe you have those "bright" SYLVANIA halogen bulbs they are notorious for causing this problem.
    Marietta, GA
    Sounds to me like either a wiring problem or a bulb problem. I would check voltage from the sockets and back to the fuse block, also check and see if the sockets are corroded. Either that or like stated above, the filaments could be loose inside the bulb.
    noobs passing on bad info.
    Quote Originally Posted by 1SOL2NV
    i would try this first
    if the fuses check out then i would check the switch and make sure its still working correctly.
    all of these are free. no reason to buy parts u dont need.
    victory is mine .::UNKNOWN::.'s Avatar
    jonesboro, ga
    i know the preludes have a relay that goes bad maybe the accords do also check the lighting relay under the hood also
    NO NWS
    l'ville
    Quote Originally Posted by CB7tuner
    hmm.. Yup i got silverstar ultras.. where should i check for the melting? theres nothin wrong at the harness.. far as i can see..
    JDM TYTE AnthonyF's Avatar
    Silverstars=waste of money.
    Did you fix the problem? Is the problem still occuring with the new bulbs?
    -Ant.
    The Carbon Fibered R6
    Marietta, GA
    I wouldn't call it bad info at all. It's simple logic really. Light goes out, replace the bulb. Just because I'm new to this board does not make me a complete idiot. That's what I get for trying to help I suppose. My word is not the final word, just a friendly suggestion to the guy. Thanks for everyone taking my suggestions so damn serious.
    barrow county
    yea like they said check fuse,wire and bulb. if u still have a problem halla at me i can take a look and maybe fix it
