Results 1 to 11 of 11
Thread: renting engine hoist
    Certified Gearhead ghostrida3's Avatar
    Default renting engine hoist
    ime picking up a new engine today does anybody know a place in or around marietta that rents engine hoist?
    305's & 350's Up 80's Avatar
    Roberta, GA
    Do you have a come-along and 2 chains? This is gonna sound really ghetto, but this is how we changed the engine in my truck. If you have this you can hook the come along to a big tree limb and chain the motor to the come-along and pull out/ put in a motor fine. But be sure its done very sturdy and cautiously. Its probably not too smart to do but its just a thought. GL with findin somethin though.
    Friends Don't Let Friends Drive Fords.
    Roberta, GA
    Keep in mind it has to be a really big tree limb..
    Quote Originally Posted by Up 80
    qft dont do it unless your willing to risk your car
    i needed a hoist, ime not doin the swap yet i just needed to get it out of the truck i was carrying so i could drop it in the garage. thanks though. ive seen engines hanging from trees and that must be why lol.
    Quote Originally Posted by ghostrida3
    2 good friends a case of beer. a lot cheaper and does the trick.
    Middle, Ga
    Do not do that! All you need is a chain and a come-along. Find two trees that are close together(Just enough that you can get the car between them), then tie the chain around both trees(doesn't matter if there are limbs or not), hook the come-along to the chain and motor and pull it out! The weight of the motor will keep the chain from sliding down. Me and a buddy have done this several times with no problems. If it can hold a 301 boat anchor, then it should work for you. Now getting it out the truck, just back the truck under the chain and hook the come-along and move the truck then push the car between the trees and your set!
    "Damn, Its Tyler"
    RaceReadyDevelopments
    Middle, Ga
    ^ thats for when you need to do the swap, if you don't have a cherry-picker! If its a 4-cylinder then you and a couple of buddies should be able two man-handle it out the truck!
    "Damn, Its Tyler"
    homie dont play that
    juss buy one
    ....True ////OFFSET\\\\
    i ended up renten one from this place in kennesaw it was like 37 for one day.
    when i do the swap ime gonna half to buy one though cuz they said its 140 to rent one for a week, which u can get one at pepboys for like 130.
    u should have just bought 1 now
