Results 1 to 10 of 10
Thread: 1989 civic si with a b16 install questions
    what time is lunch?
    woodstock
    Default 1989 civic si with a b16 install questions
    Ok I have a little project going at my house right now that I need to get running so i can take the crx off the road.
    I have a 89 civic si. See below.
    I'm putting in a B16 with a ls cable tranny. See below.
    I'm having a few issues. These are probably really minor but I would like an answer.
    I have the 1989 wiring harness and everthing matches up pretty good except the following.
    and
    In looking at the round plug it looks like it needs to be lengthend to reach the back of the intake manifold. I do not have anywhere for the rectangle plug. On my civic it went to a pressure pot on the back of the manifold. where goes it go on the b16.
    also on the ls tranny I have two hoses coming out of the speed sensor where do they hook up or do I use a d series speed sensor.
    The sooner I can get this on the road the sooner I can the rex off the road to restore.
    Thanks
    Rich
    Southside of The Jungle
    the hoses on the speed sensor Dont hook to nothing I believe they were for oil overflow from vc, So extra oil would go to tranny
    EF Enthusiast jfrolang's Avatar
    far far away
    the hoses on the speed sensor were for the speed-sensitive power steering. Just loop them together to close the system.
    the first harness i believe is not used which is located behind the motor correct, and the second harness no clue
    just drop the motor is and crank it up and see if motor is running correct.
    college park
    yeah i did the same with mine on my si tranny just bend them together also pick up this months issue of project car has a full ef swap how to
    now with LSD
    what time is lunch?
    woodstock
    Default b16 install with questions regard ac
    I've ordered the magazine so will read when comes in.
    Anybody running ac in their hatch or rex with a b16. If so what bracket did you use and also what compressor?
    I've read a del sol bracket and also hasport one but they are really proud of their work and the price reflects that.
    I'm gradually getting the engine in but it is taking time since this is just a project car for me.
    I've got the mounts in and then all the wiring is done even the additional stuff so it is coming along but I'd still like to have ac when I'm done.
    Thanks
    Richard
    far far away
    Innovative also sells an adapter bracket so you can use the stock AC compressor. It's a little bit cheaper than the Hasport piece ($150 vs. $200).
    what time is lunch?
    woodstock
    Default b16 ac
    thanks.
    I'd ditch the ac if the wife wasn't gonna drive this thing but the wife and two kids are gonna run around in when it is done. Cant put two small kids through that when I do it every day in my rex.
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    Quote Originally Posted by rbwdriven
    thanks.
    Yes you can
    j/k
    Your mom's bed
    thanks.
    ^^^never hear of factory air? lol j/k yeah it's definatly too hot for kids to riding around w/ no A/C, the wife too. she might try and punsh u by not giving u any for a few months, just cuz she had to ride w/o A/C.
