Results 1 to 37 of 37
Thread: Supercharging my Sol!!!
    It's the Birdman bitches! BirdmanSRT's Avatar
    Austell, Ga
    Smile Supercharging my Sol!!!
    What the hell is up IA??? So anyway I just picked a JRSC for the sol and I was wondering if anyone on here has one and what they think of it?
    04 Dodge SRT-4
    BrandenJ has a JRSC on his sol.
    DUH-KYOO-LUHHH
    ive always heard that turbos are better for hondas, but idk how much truth there is to that.
    Stang Mod slostang's Avatar
    Southside
    sc's are limited to about 8-10 of boost but the offer more tq and constant low-mid range power but for honda that rev 7k+ sc's really suffer on the top end where turbos shine... just my $0.02
    JDM TYTE AnthonyF's Avatar
    Go turbo. You dont get the results you want out of an S/C. Take it from me.
    -Ant.
    The Carbon Fibered R6
    Certified Gearhead brandenj's Avatar
    small town loganville
    i'm running a jrsc on my sol, very reliably and hella fun to drive, but if your looking for low 1/4 mile times i would go w/ turbo
    i think its cool if you SC a honda. not as common, but you wont make as much power per lb of boost with a supercharger. i know the JRSC dont produce mass amounts of power, but it will make for a fun drive either way.
    I CAN HAZ 8 CYLINDERS?
    Cameron Flaisch Photography
    Canon Shooter
    Shifting_At Redline Mdeezy's Avatar
    if your goals aren't for super high HP, and are looking for more low to mid range. super charge it.
    Southside
    Quote Originally Posted by Mdeezy
    if your goals are not for super high HP, but are looking for more low to mid range. super charge it.
    fixed.
    thanks. thats what I meant to say
    Southside
    lulz. and your welcome.
    I'm happy w/ mine, just dont run an fmu get it tuned you'll be alot happier w/ it. I'm hoping to make 8 lbs of boost on mine soon but i've been tracking down some problems, anyways gl
    . eg mike's Avatar
    ga
    Quote Originally Posted by brandenj
    your engine looks sick in your sig
    Is it a b or a d?
    Austell, Ga
    Thanks for all the input anyway I got it on yesterday and it is making some noise so I am going to have to tear it back off and get it rebuilt. So boo for the seller that told me it was running perfect!
    04 Dodge SRT-4
    Austell, Ga
    Does anybody know who will rebuild a supercharger?
    04 Dodge SRT-4
    Canton, GA
    if you dont care about peak power, want instant boost, gobs more tq/better midrange go SC. My 88 S/C MR2 wasnt the fastest top end car, but with a pully swap (cusco 16psi) and exhaust it was a rocket off the line. There was no punch in the seat, it was a constant pull all the way to the moddest 7200 rpm redline
    theoldone.com
    jacksonracing
    those are 2 places right there that will rebuild it for you and for a little extra they will port it some to, but these are the most expensive 2, anyplace that services eaton units should be able to do it though.
    Austell, Ga
    Thanks alot! +1 for you! What do you have done to your car?
    theoldone.com
    jacksonracing
    04 Dodge SRT-4
    i have the kamikazi header(the best header for jrsc b/c of the larger runners and collector)
    cai
    colder ngk plugs and wires along w/ a cooler temp thermostat from jr
    i also got mine tuned by scotty, so i could up the boost when need be, but at 5lbs i got 150hp in 98degree weather but now i got it back up to 6lbs so i should be more around 155-160hp
    i good way to bump up the boost is with a y8 crank pulley on ur d-series, the boost will go from 6 to 8lbs, at least thats what i'm trying right now
    Southside
    cai
    damn I thought you could get 10psi with a sc if you tried hard.
    yeah thats my plan a company called asp racing makes can custom make me a nose cone pulley that can put me at 10.5 to 11 psi and it comes w/ a better lip than jr's pulley did so less of a worry about thrown belts....theres a guy i know thts going over 10lbs right now but that s/c like to get hot so i wouldnt going ovre the 10.5 lbs unless u can inter coll it some how
    Exactly my point. You have to run so much more boost to get as much power as a turbo running half as much. If you run too small of a pulley you will have belt slippage, over heating of the belt, tearing of the belt, melting of the belt, or even over revving the S/C
    -Ant.
    Austell, Ga
    Hey Branden do you still have your cruise control?
    04 Dodge SRT-4
    dc5
    ATL, GA
    i made 280whp @ 11 psi on a jrsc k20 @ 102 iat and 312.4 whp... on 100 octane tune @ 105 iat.. Of the iat were in the 60s/70s, it would be easy +6/10 more whp
    no mine is an del sol s, that a d16z6 got a home in haha, but i've never had trouble w/ throwing belts or getting to hot under the hood but then again im only at the 6lbs
    6-7psi on a small turbo with a z6 will net you low end TQ and 180-190hp pretty easily.
    dc5
    ATL, GA
    yeah, run the turbo for more whp/tq on a z6...
    so any more news on ur sol....
    cai
    have you ever ran it with a sri? I just heard that it works the SC to hard to draw air through a cai.
    i tried it both way....i actually believe the cai works better just b/c w/ the jrsc the under hood temps are outrageous, the cold air reduced that alot, but i hear the short ram makes it seem more responsive w/ the jrsc, but w/ a jrsc u really need it more on the top end anyways, i beat most turbos off the line its the 1/8 mile and pass the jrsc's dont perform well.....
    cool, thanks
    cai would be my recommendation too. the intake charge on a jrsc can get pretty extreme. anything you can do to cool the intake charge is very helpful (ie: cai, water inj, etc).
    ok, will do. Like i said, i was just nervous of doing that because of the rumor it worked the charger to hard, but your obviously not suffering from that so i guess its good to go.
    Austell, Ga
    Yeah I got on the supercharger and it runs great! I am looking for a few more thing to finish up the sol! Then I will probly sell it and start a new project!
    04 Dodge SRT-4
    ^^sounds good, maybe u should drive it a while and enjoy it, haha. but to each he's own i guess...good job man
    you should look into JR's water injection kit. great bang for your buck mod for the sc. cool car!
