Results 1 to 40 of 40
Thread: debating...someone talk me out of it...
    Flowery Branch
    Exclamation debating...someone talk me out of it...
    so my car is about 80% of the way done, got my JDM h22 fully built, broke in, and it's actually in my 90 4 door ef, i have done a wire tuck on both chassis and engine, im almost done with my turbo manifold that i have 1200$ wrapped up just in parts, i need the following to be 100% done and on my way to the dyno.
    DA spindles (picking up saturday)
    harness modified
    odb0-obd1 jumper
    axles from raxles.com
    hondata s300 w boost solenoid
    starter and housing
    -12 line for catch can on VC
    intercooler
    seats installed
    5 point harness's installed
    10 gallon fuel cell
    things i own that need to be installed
    6an line to and from tank with all fittings
    weld up golden eagle intake mani from being chopped to fit
    holley fuel pump
    stage 5 competition clutch, sprung 4 puck with hd PP
    adapters for cable to hydro trans
    everything else is done but if you look at my list of things to be done...well of all the things listed were still talking 2-3k not including tuning which would be in the 800-1000$ range, my problem is my first child is on the way due in late aug early sept...my goal was to have this thing done by the time he arrived, and it's not looking good! i still dont have it back home from the shop! and im certainly not going to get that kind of money that quick enough to finish, so the way i see it is i should not spend any more money trying to get this thing done because under the current circumstances and deadline it cannot be done with my budget and time frame, im seriously debating parting this thing out...just wondering what everyone thinks at this point, i could keep it and slowly do it but between work and a newborn and a house to take care of...i just dont see it happening.
    ACC CHAMPS bigdare23's Avatar
    ECEFC.com
    baby>car
    Flowery Branch
    i agree
    Scottish Scotsman's Avatar
    on the road to recovery
    baby>car
    Well I see what your saying, but.....Keep it. Your pretty close, so just let it sit to the side and work on it when you get the chance. It may not be for a while, but beats starting from scratch again.
    also a valid point
    EE OG Revmaynard's Avatar
    Hell, if anything keep it and finish it later down the road. If it were possible to get the parts you need I'm sure some of the squad wouldn't mind a wrench meet.
    Bozzio for president.
    1.5T AnTi-PooN's Avatar
    L'villE
    ^^^true dat
    All Motor EK N/A EK's Avatar
    On IA.com
    x 2
    Hamilton, GA
    x3
    Senior Member sakasaku's Avatar
    Marietta, GA
    i would be more they happy to give a deal on parts u need for hatch and four door and wrench on it to!!!!!!!
    Lurking
    Your mom's bed
    UR SON IS THE MOST IMPORTANT FACTOR RIGHT NOW, IF UR HURTING FOR MONEY THEN I WOULD GO AHEAD AND PART IT OUT CUZ BABIES ARE EXPENSIVE AS HELL. I KNOW I USED TO WORK AT BABIES R US. BUT AT THE SAME RATE IF UR NOT HURTING FOR MONEY THEN I WOULD KEEP THE CAR AND WAIT TILL U HAVE THE TIME AND MONEY TO WORK ON IT. BUT THATS JUST MY OPINION
    I would say don't start from scratch and just leave it on the side and work/put money into when you can.
    Southside of The Jungle
    Im sure the baby would love hearing vtec once they get about 1
    Rx7 Drift / EF grip Kalifornia087's Avatar
    Oakwood.
    You should have listened to me... And bought another Accord! Dammit!
    <3
    Austin
    FC - Death by rotary forever
    CRX daily... Gas prices suck, i love my HF
    Columbus, OH
    Well geez what a change scotsman. I'd keep it and finish it when I can down the line. I mean... it can even be a father/son project at some point later (if it sits that long) so just keep it.
    CHASE ->>>
    WHAT MATTERS
    Flowery Branch
    well guys, i have began parting it out, but on the bright side of things they guy buying the entire set-up had a longblock i got from him, just knocked some cash off the bill, here is what im working with now.
    D16y7
    ceramic coated CP pistons
    scat H beam rods
    ARP rod bolts
    blockguard
    ARP head studs
    ACL race bearings
    going to finish it up with a ported polished fully built head, cam gear, and i already have a ZEX direct port kit im throwing on it, looking for 140-150na and 300ish on spray. however once i get everything ready i can only have the car down for the weekend, friday night i will pull the motor and all the junk i dont need, saturday wiring harness goes in, fuel pump, motor mounts replaced, saturday evening motor goes in, wired up, plumbed up, you get the idea, sunday getting everything double checked and tucked away, monday to see ED the dyno, i plan on hosting a cookout and what not on that day in case i need some extra hands/knowledge...no matter how much you know...someone else always knows how to do it faster or better.
    Your mom's bed
    well im glad u didnt give up on it completly, but i would have loved to see that 4 door beasting on everything in the streets
    Flowery Branch
    Quote Originally Posted by 00CelicaGT
    me too, i'll get another one or do what i was going to do originally which is get that motor in a CVCC, did some research and i think the ONLY one that has an H swap is a full show car that can't even steer because they used stock steering set-up rather than replacing the PS pump with a hydraulic ram style set-up like on huge lifted jeeps etc...imagine seeing a cvcc on the highway then woooooooooooooooooooooooosh and two ghost tracks off the tires...
    Badass! It's a better compromise than giving everything up. I can't wait for you to get that car rolling!
    What's going on at Kinetic?
    Just look at it this way, you can use that sweet whip to drive to your previously owned house and visit your baby and girl after she leaves you
    Quote Originally Posted by Clegger
    Wtf dude?
    Flowery Branch
    damn man... you must not know either one of us, which would make you ignorant among other things right off the bat to say something like that and not have any idea wtf your talking about, hell i think you might even be jealous.
    my buddy comes back from the koni challenge in mid ohio today so i will talk to him when he comes to drink my beer.
    Quote Originally Posted by onebaddXJ@teamFX
    Awesome. I'll hit you up on here after I get off work tonight and see how it went. Sorry, I'm impatient, the anticipation is killing me!!!
    D16y7
    scat H beam rods
    ARP rod bolts
    blockguard
    ARP head studs
    ACL race bearings
    You poonapple, dont have a cookout, come to our accord meet Sunday at the V.
    TOOK THE WORDS OUT OF MY MOUTH.
    Oakwood.
    Glad to hear she's going to at least get finished up. 150whp with the suspension and such will still make that car lots of fun.
    Now you just need my 14s for grip.
    Flowery Branch
    bought the 14's, and i think everyone is mis understanding, the ia member who bought the motor also bought the car, has a sprayed na h22 he's dropping in it and throwing my built boosted one in his EG, this motor i am working on will be going into my slammed hatch
    Your mom's bed
    at least the hatch will get so loving now lol.
    Flowery Branch
    thats right!
    Columbus, OH
    LOL my bad. I was talkin completely to the wrong person. I didnt kno this was UR thread JX. I coulda swore it was Scotsman's lol. But still my message stands. I'd keep it and just let it sit till its done. I'd be damn'd if I'ma give up on somethin like that after all that time and effort and watch some ricer get ahold of it and finish it then destroy it in 4days.
    CHASE ->>>
    WHAT MATTERS
    Flowery Branch
    the new owner will take good care of it and have it done in no time, keep your eyes peeled...
    Got any good news for me? lol
    Flowery Branch
    not yet my man, he was a no show today, went home and straight to bed for work again tomorrow, i will be stopping by there to drop off my head with there machine shop so i will know then
    Flowery Branch
    can't man got a friend coming back form germany for two weeks
    Good talking to ya today, maybe next time i'll be able to swing by the shop and take a look at that bar.
    Well if theyre coming back for 2 weeks, then bring em along.
    Yo, you think there will be any chance of these before next Friday? I wanted to get to install them before the mountain run.
    Flowery Branch
    sorry, haven't checked the thread in quite a while, he should be bringing them home today
    Awesome! Just let me know and we can plan meeting up!
