Results 1 to 29 of 29
Thread: 90 Civic Trouble - Starting Trouble
    Kennesaw, Ga
    Default 90 Civic Trouble - Starting Trouble
    I'm about sick of this f*cking car. I've replaced the fuel filter, ignition wires, battery ground, and the ignition switch but this car is still having trouble starting. When it gets going, it's fine. Jumping it off works sometimes and, for a while, holding down the gas while cranking it would work. Now it's just being gay and I'm about ready to burn it.
    Can anyone help?
    1.5T AnTi-PooN's Avatar
    L'villE
    what exactly happens
    yea...explanation...from the sounds...still sounds like battery connection. easiest thing to fix, but usually the most tedious
    freezrburn frostbyte's Avatar
    douglasville
    or fuel pump or relay
    Kennesaw, Ga
    Quote Originally Posted by AnTi-PooN
    Turn the key, it makes that "woom woom woom" sound then starts to die out. I can't help but think it's something electrical. Still, the alternator, ignition switch, ground, and battery are all good. The distributor is clean as well.
    u dont ever lose power at all right? lights dont get dim or go out inside?
    Kennesaw, Ga
    Quote Originally Posted by PBS
    Nope. Once it's cranked up it runs like a champ.
    fuel pump and new battery...
    Kennesaw, Ga
    Fuel pump? You really think so?
    Battery cell is good.
    L'villE
    dizzy leaking?
    douglasville
    is the fuel pump hum when it turned to on position... how much gas is in it....
    lol my accord had trash (alot) in the tank, if it got to a 1/4 tank of gas soon as u pressed in clutch it cut off though was eletrical til i dropped the tank and cleaned runs perfect now...
    gotta be one of the three essentials
    air fuel or fire and if ur gettin spark an air gotta be fuel... lol or ecu
    Kennesaw, Ga
    I'm taking it over to a buddies place tonight to check the pump and make sure th engine is getting enough spark. I'll let you know how it turns out.
    Here's hoping we can source the problem.
    i do...sometimes when the fuel pump is gone it takes a while to crank...and when u said it dies down, itt sounds like its draining your battery
    have u tried beating on the gas tank w/ a rubber mallet when it does wat it does?
    Kennesaw, Ga
    No, I can't say that ever came to mind. lol
    lol try it when it does it again...vibration of the hit will usually trigger/vibrate the fuel pump to work and it will usually crank right up unless the pump is completely shot
    douglasville
    booflmmfao.... then if it dont drop kick it in the forehead with a broken cheetoe
    Sounds like the main relay. Gotta love all these people giving input when they don't know WTF they are talking about. The relay is behind the dash kinda behind the flip-down change holder. Sometimes you're able to tap on the relay and the car will start. Its usually more predominant when its hot outside. The fuel pump will not work when the relay is acting up.
    center field
    sounds like it could be the temp sensor in the side of the head , it will cause it to do this , hard to start but then run fine.
    Scottish Scotsman's Avatar
    on the road to recovery
    lol , you caught the "90" civic part too huh? EF's are notorious for the main relay goin out , seriously Ran , try changin that , it would be the first thing i would check , pm smokeyJ he has quite a few good ones at his house
    Yea these people who are responding have no clues about common problems with this chassis.
    troof , i've had enough EF's , to know the nightmares they always have ,lol
    Hiawassee, GA
    I may have a spare main relay your welcome to if I can find it. I'll look in the AM and post as soon as I can.
    -Zach-
    1987 Toyota Pickup - Toy
    u...stfu, i'm giving the small amount of knowledge of what i know about cars to help him solve his problem...not to mention u just mentioned something that i mentioned about the fuel pump not working smart guy, gtfo
    Kennesaw, Ga
    My buddy had an extra fuel pressure regulator so we swapped that out last night. Car cranked right up so I'm hoping that it.
    I'll keep the main relay in mind and post up here if it gives me any trouble in the next couple of days. Thanks guys!
    douglasville
    lol even i said it sounds like the fuel pump or relay u dusch bag...
    U JUS GOT DROP KICKED IN THA FOREHEAD WITH A BROKEN CHEETOE!!! [SIGPIC]
    sounds good man...i hope that solves it
    ok so tell him its a fuel pump, he goes through the trouble of REMOVING the gas tank and replacing it, several hours and $100. still wont start. good job.
    douglasville
    slaps forhead no ecotech @ss said check fuel pump to see if it hums if not common sense says is there a fuse of relay for that let me see.... then if theyre good u proceed... smmfh
    wtf are you trying to say? your english is very poor
