Results 1 to 21 of 21
Thread: Brabus Bullit Black Arrow on Sale. Twin Turbo V-12 w/ 974 lb./ft in a C-Class
    Everywhere
    Talking Brabus Bullit Black Arrow on Sale. Twin Turbo V-12 w/ 974 lb./ft in a C-Class
    The Four-Door V12 Biturbo Stealth Super Sports Car With 730 hp (720 hp SAE net), 1,320 Nm (974 lb-ft), 0 - 300 km/h (186 mph) in 24.5 seconds and a Top Speed of More than 360 km/h (225 mph)
    Ultra powerful, ultra fast and conspicuously inconspicuous: The four-door stealth super sports car BRABUS BULLIT BLACK ARROW offers performance superlatives like no other car on the market: The basis for the car is the body of the new C-Class sedan, covered with a special matte-black coating. The BRABUS SV12 S Biturbo twelve-cylinder engine was dropped into the engine bay with almost surgical precision. Performance is staggering: 3.9 seconds from rest to 100 km/h (62 mph), 24.5 seconds for 0 - 300 km/h (186 mph) and a top speed of more than 360 km/h (225 mph). BRABUS produces the BULLIT BLACK ARROW in small-series production starting at 348,000 Euros MSRP.
    The BRABUS BULLIT BLACK ARROW ensures that the world's fastest sedans continue to come from Bottrop. The BRABUS BULLIT BLACK ARROW follows in the footsteps of the 330-km/h (206 mph) BRABUS E V12 based on the W 210-series Mercedes E-Class, the 350.2-km/h (219 mph) E V12 Biturbo of the new W 211 generation and the world's current fastest sedan, the 365.7- km/h (227.2 mph) BRABUS ROCKET based on the Mercedes CLS.
    Numerous modifications to the reinforced body were necessary to install the turbocharged V12 engine in the C-Class engine bay. The BRABUS SV12 S Biturbo engine is derived directly from the BRABUS ROCKET and uses the latest Mercedes S 600 engine that has been completely reworked in the company-own engine building shop.
    Nothing beats displacement except even more displacement: A crankshaft with longer stroke, larger cylinder bore, and special pistons and piston rods increase displacement of the twelve-cylinder three-valve engine from 5.5 to 6.3 liters (336 to 385 cu. in.).
    Cylinder heads optimized for faster gas exchange and high-performance camshafts also contribute to the increase in power output. They are assisted by a more efficient dual turbocharging system, special manifolds, larger turbochargers and larger intercoolers. Because of space constraints in the C-Class body an entirely new stainless-steel high-performance exhaust system with low back-pressure metal catalysts had to be developed.
    The BRABUS motor engineers used state-of-the-art engine test benches to program new mapping for engine electronics and on-board diagnostics. The new mapping ensures optimal power yield while meeting strict EURO IV emission limits.
    The BRABUS SV12 S Biturbo displacement engine, lubricated like all BRABUS high-performance engines with ARAL Synthetic motor oil, produces 730 hp (720 hp SAE net) / 537 kW at just 5,100 rpm. The peak torque of 1,320 Nm (974 lb-ft) is limited in-car electronically to 1,100 Nm (811 lb-ft).
    Power is transferred to the rear wheels via a reinforced five-speed automatic transmission and a BRABUS limited-slip differential with a locking rate of 40 percent. Customers can choose from two final drive ratios. The BRABUS BULLIT BLACK ARROW features all modern driving dynamics systems such as ABS, ASR and ESP.
    The matte-black stealth street rocket delivers unique performance: Just 3.9 seconds pass for the sprint from 0 - 100 km/h (62 mph), 200 km/h (124 mph) is reached after just 10.49 seconds. And after just 24.5 seconds the car shatters the 300-km/h barrier (186 mph). Top speed is more than 360 km/h (225 mph).
    At these speeds favorable aerodynamic properties are absolutely essential. The BRABUS BULLIT BLACK ARROW was honed to perfection in the wind tunnel. The BULLIT front apron features large air ducts to supply cooling air for radiators and front brakes. Its sophisticated design further reduces lift on the front axle. Its aerodynamic counterparts in the rear are a three-piece rear spoiler and a rear apron with integrated diffuser. Both front and rear aprons are made from especially light yet highly robust autoclave-baked carbon fiber.
    A wider track optimizes directional stability so elementary at speeds beyond 300 km/h. The BRABUS designers have styled aluminum wheel arch flares for front and rear axle. They are seamlessly melded to the production body and add six centimeters (2.4 inches) to the C-Class width. BRABUS rocker panels optimize the airstream along the sides. They also feature integrated entry lights that make entering and exiting the vehicle safer in the dark.
    The visual appearance of the BRABUS BULLIT BLACK ARROW is further characterized by the new hood. Its integrated 'gills' are not just distinctive features, they also ensure the engine's thermal health.
    The wheel arch flares provide space for especially wide matte-black BRABUS Monoblock S light-alloy wheels with high-performance tires from technology partners YOKOHAMA or Pirelli. The 9.5Jx19 wheels on the front axle are shod with size 265/30 ZR 19 tires. The rear axle is fitted with size 10Jx19 wheels and size 285/30 ZR 19 tires.
    The height-adjustable coil-over suspension was developed specifically for the BRABUS BULLIT BLACK ARROW. The gas-pressure shocks feature ten selectable settings each for bound and rebound. They provide a sporty yet comfortable ride and safe handling in any situation. Sport stabilizers reduces body roll to a minimum during fast cornering.
    The BRABUS high-performance brake system can handle even the most extreme stress. It features 12-piston aluminum fixed calipers on the front axle that grip vented and grooved 380 x 37 millimeter (15 x 1.46 inches) brake discs. The rear axle stops with 360 x 28 millimeter (14.2 x 1.1 inches) discs and six-piston aluminum fixed calipers.
    Exclusive individuality also abounds in the interior of the BRABUS automobile: The standard equipment package includes a fully leather interior hand-crafted in the company-own upholstery shop from the finest Mastik and Nubuk leathers.
    The custom BULLIT seats offer a perfect combination of comfort and lateral support. Their carbon-fiber rear covers lend the interior an especially sporty feel. This look is complemented by carbon-fiber components on dashboard, center console and door panels as well as by the ergonomically shaped sport steering wheel and aluminum pedals and shifter.
    BRABUS BULLIT BLACK ARROW - Technical Data
    Body
    4-door sedan based on Mercedes-Benz C-Class, W 204 series
    Steel unibody widened with BRABUS fender flares by 60 mm (2.36 inches). BRABUS hood with integrated gills.
    BRABUS BULLIT aerodynamic-enhancement kit with BULLIT front and rear bumper manufactured from carbon fiber baked in an autoclave. Rocker panels with integrated entrance lights, three-piece rear spoiler.
    BRABUS BULLIT BLACK ARROW with matte-black coating.
    Measurements:
    Length 4.590 mm 180.7 in.
    Width 1.830 mm 72.0 in.
    Height 1.402 mm 55.2 in.
    Curb weight 1,850 kg 4,079 lbs.
    Engine
    BRABUS SV 12 S Biturbo displacement engine based on Mercedes 600
    V12-cylinder 3-valve light-alloy engine with twin turbochargers
    Displacement 6,233 cm³ (380 cu. in.)
    Compression ratio 9.0 : 1
    Rated power 730 hp (720 hp SAE net) / 537 kW at 5,100 rpm
    Peak torque 1,320 Nm (974 lb-ft) from 2,100 rpm (electronically limited to 1,100 Nm - 811 lb-ft)
    Fuel: Super plus (98 octane)
    Motor oil: ARAL
    BRABUS SV 12 S Biturbo engine conversion consisting of:
    Displacement increase to 6.3 liters with special crankshaft with longer stroke, enlarged cylinder bore with corresponding larger pistons. Both cylinder heads feature flow-optimized ports and special camshafts. Two high-performance turbochargers with special exhaust manifolds; more efficient intercooling system and BRABUS stainless-steel high-performance exhaust system with low-back-pressure metal catalysts. Newly programmed mapping for engine electronics and on-board diagnostics.
    Drivetrain
    Rear-Wheel Drive
    Reinforced five-speed automatic transmission
    Gear ratios:
    1st gear 3.59
    2nd gear 2.19
    3rd gear 1.41
    4th gear 1.00
    5th gear 0.83
    BRABUS locking rear differential with 40 percent locking rate
    Final drive either 2.65 : 1 (top speed 315 km/h - 196 mph) or 2.24 : 1 (top speed 350 km/h - 217 mph - electronically limited).
    Suspension
    Independent suspension front and rear with height-adjustable BRABUS coil-over suspension.
    Front axle:
    Three-link, anti-dive geometry. Height-adjustable BRABUS struts with coil springs and gas-pressure shocks featuring ten settings each for bound and rebound; BRABUS sport sway bar.
    Rear axle:
    Five-link, anti-dive and anti-squat geometry. Height-adjustable BRABUS struts with coil springs and gas-pressure shocks featuring ten settings each for bound and rebound; BRABUS sport sway bar.
    Wheels:
    BRABUS Monoblock S light-alloy wheels with YOKOHAMA or Pirelli high-performance tires.
    Front: 9.5Jx19 H2 with 265/30 ZR 19
    Rear: 10.0Jx19 H2 with 285/30 ZR 19
    Brake System
    Dual-circuit brakes with Brake Assist and BRABUS high-performance brake system.
    Front: BRABUS 12-piston fixed aluminum calipers with vented and grooved 380 x 37 mm
    (15 x 1.46 in.) steel brake discs.
    Rear: BRABUS six-piston fixed aluminum calipers with vented and grooved 360 x 28 mm (14.2 x 1.1 in.) steel brake discs.
    Performance
    0 - 100 km/h (62 mph): 3.9 sec
    0 - 200 km/h (124 mph): 10.49 sec
    0 - 300 km/h (186 mph): 24.5 sec
    Top Speed: More than 360 km/hr (225 mph)
    Vossen CV3 20x9 & 20x10.5
    woodstock ga
    favorite brabus car yet..... than again i love all of them
    the old man NAIZBST's Avatar
    nice
    v2.0 IndianStig's Avatar
    Sep 2004
    Gwinnett County
    Wow, I would love to go to Bottrop and come back with one of these as a DD! HA, who am I kidding, Carmax, here I come!
    Shop Lackies FTW Complication's Avatar
    Marietta, GA
    that Interior is sex!
    B5 S4=problems Reaper's Avatar
    Crossfit
    mercades ftl
    lexus ftmfw!!
    but thats still hawt
    Dunwoody
    that is defintely the best brabus yet. the amg was a beast but this...........undescribeable.
    Beastly !
    That's just wrong.
    The Green Jeep STI101's Avatar
    Dunwoody
    Holy ****!!
    Newnan
    it is black like my anus
    in a good way.
    learn to english
    "murdered out"
    love it.
    EAT DOG white_rice's Avatar
    lawrenceville
    a fo do i wouldnt mind owning
    Quote Originally Posted by Complication
    x2
    the start of 285
    pretty nice.. but i have to object as to the nicest brabus
    ..can you say slr? =P
    NO PISTONS DESTRO_91's Avatar
    I-20 East
    Absolutely EVIL! Yeah, that Brabus SLR is even more evil. But the matte black just looks so sick on this luxury car.
    I'm allergic to pistons.
    Macon
    it's a steal at $515,000.
    Land Rover LR3 HSE
    this is the definition of a sick ass car
    Duluth, GA
    i like...anti-bling c class
    IA's hawaiian haynbtu's Avatar
    douglasville,georgia
    thats bad@$$.the only mercedez i that looks like its only built for speed and has a mean street look
    IA's hawaiian 90 black s13 hatch
    DAMNNNNNNNNNNNNNNNNNNNNNNNNN
