Results 1 to 11 of 11
Thread: JDM GSR (B18c) Vs. USD GSR????
    is doin you
    buford
    Lightbulb JDM GSR (B18c) Vs. USD GSR????
    ok...fast question..im just messing with my own head...
    wuts the diff between the U.S GSR and the JDM GSR????
    i looked around... i saw that the the JDM type R block (B18c) was the same as the JDM GSR's block...DIFF in the head???...
    any one??
    you will get reps:boobies:
    Where Am I
    All type r blocks have a different head.... they all have the PR3 (B16) head now the differences between the U.S. blocks and the JDM I'm not really sure usually its only like 5-10 horsepower.....
    is doin you
    buford
    so then its the same block??? wut aboiut the US GSR vs. JDM GSR
    Quote Originally Posted by Turbodude06
    Where Am I
    Its the same block but the type r crank is balanced better or has counter weights, the rods are I believe coated with something and they have more compression too, someone correct me if I'm wrong here......
    is doin you
    buford
    ohhh ok...now wut about the U.S GSR and JDM one??
    compression is different
    is doin you
    buford
    in the us vs. jdm?? thats all???..
    Where Am I
    I always thought it something to do with the JDM motors not having any kind of SMOG/Emission stuff on them, IDK
    is doin you
    buford
    i found this...it right????
    the difference in the USDM B18C1 and the JDM B18C1 is the ECU maps(more agressive because of fuel availiable) and the fact they have higher octane gas over there available at the pump and Less restrictive emissions. So these 170hp B16's and 180hp B18c's are just like USDM engines with the exception of compression ratio and other small features that protect the engines life
    Marietta, GA
    ^^^ that's pretty much it. they tune the cars a little differently because of the differences in emmisions and fuel, but all the actual parts are the same between usdm and jdm (except for the japanese writing). as for type r heads, they are pretty much exactly like a b16 head, but with different internals. check the compression chart sticky note to see the difference in power and displacement.
    ATL DA SQUAD MEMBER #1
    HONDA_PARTS_CLEANUP_CLICK_ME
