Thread: Amp recommended for two 12w3-d6 JL audio subs?
    Senior Member Schugg's Avatar
    Default Amp recommended for two 12w3-d6 JL audio subs?
    a guy from my shop gave me 2 12w3-d6 subs and a box, ive been out of audio stuff for a while and i never really knew all the technical stuff about audio work, just how to hook it up..i was wanting to know what kinda of amp i would want to get for this, 1 or 2 channel?, how many watts, and all that. he currently has them wired like this below, except each speaker goes to its own + terminal on the box and its own negative terminal, totaling in 4 box terminals
    here is my current wiring
    should i do that or rewire it this way and look for an amp with these wiring settings?
    if this ad i found is the same speaker here is all the info, it looks the same and has the same name, so im assuming it is.....haha
    12W3-D6 12" 250w Dual 6 ohm
    Nominal Diameter: 12 inches (300 mm)
    Continuous Power Handling: 250 Watts
    Voice Coil: 2.25" diameter, 4-layer, Kapton former
    Available Configurations: Dual 6 ohm
    Xmax (one-way, linear): 0.46"-0.51" (11.7-13.0 mm) depending on specific model
    Sealed Enclosure Range: 1.00-1.50 cu.ft. (28.3-42.0 liters)
    Ported Enclosure Range: 2.00-3.00 cu.ft. (57.0-85.0 liters)
    VRCª Technology: YES
    - 1993 Honda Civic VX
    - 2008 Acura TL-S
    Hiram, GA
    I would wire them at 1.5 ohm and use an amp like this one http://www.woofersetc.com/index.cfm?...roduct_ID=4209
    Hifonics arent going to win you an SQ competition, but they are reliable amps that put out pretty decent clean power. They are slightly over-rated though.
    Blacc Panther member
    look to ya left
    Quote Originally Posted by BanginJimmy
    hi fi is your best bet.. good bang for the bucc
    ok thanks, i read they were good on some google searches too, ill look into them. never heard of them til today.
    - 2008 Acura TL-S
    Hiram, GA
    I will be using a TXi 4008 and 6008 in my own truck.
    what subs do you have?
    - 2008 Acura TL-S
    Hiram, GA
    2 MTX 4512's.
