ok i found out oday the other hatch i have has neuspeed springs soo...
neuspeed> gc's?????
neuspeed> gc's?????
What kind of neuspeed?
NEUSPEED SPORT (green)
Drop: 2.0" front
1.8" rear
front: 4.9 Kg/mm / 275 Lbs/in
rear: 4.0 Kg/mm / 225 Lbs/in
NEUSPEED RACE (yellow) Drop: 2.25" front
2.0" rear
front: 10.2 Kg/mm / 575 Lbs/in
rear: 9.6 Kg/mm / 540 Lbs/in
Now for gc's
GROUND CONTROL COILOVER
( Off the shelf spring rates)
Drop: .5" to 3.5"
Front: 6.3 Kg/mm / 350 lbs/in
Rear: 4.5 Kg/mm / 250 lbsin
This is all depends on what you want from your car and my answer is my own opinion since I have use neither. All the autox's out there swear by gc's but why waste your money whenever you have nice springs already? Just by some neuspeed shocks, because I'm pretty sure they valve there shocks to match there springs. So you can just keep what works.
i still want your struts but as you can see iam am in no need what soever for more springs
GroundControl doesn't make manufacter the springs, GroundControl uses Eibach springs on their (GCs)adjuster sleeves & seats. Eibach is a very reputable company and has been around for quite a while, i'd figure out what rates they are and keep the Eibachs.
Alan has GC's thanks to me.![]()
Bozzio for president.
yea but i'd lose them for struts too...
Eibach makes those spring specifically for the koni's I put the spring rates up early.
