Results 1 to 26 of 26
Thread: ACL Bearing for LS/VTEC?
    Cobb County
    Default ACL Bearing for LS/VTEC?
    Someone told me to get some new bearings for my swap?
    Found this website:
    http://www.tunerschoice.com/xq/aspx/...qx/Product.htm
    They have the B18B or the B18C1. Which one would be better?
    if ur using a ls bottom end i would use the ls bearings thats just me.
    your moms house
    you need to use the bearings for the crank your using some are narrower than others
    Around metro-ATLANTA & IA!!
    Cobb County
    Sounds good to me. Thanks guys.
    the one you'll need is part # 9351946
    fo sho
    Cobb County
    Quote Originally Posted by pxhoang0408
    fo sho
    Do I need to get the whole kit?
    #9351904
    everywhere & nowhere
    ^^ If you have the engine broken down that far, then go get the crank turned... they will put the bearing sizes you need on the crank-card.
    Cobb County
    Yeah, it's down that far. Lol. So I guess I can do that then. Thanks. But I do need to order the bearings and give it to the mechanic to put it on right? Or is part of their job is to measure and order?
    No - you go to the COMPETENT machine shop of your choice -- preferabbly one familiar w/ imports -- but for turning a crank they should all be fairly equal. They will turn the crank and measure it for bearings (chances are it will still be STD when they are done, but u never know).
    Your crank will be returned to you in a heavy plastic bag, and have a toe-tag on it (crank card) --- will tell the date it was turned and/or micropolished and they will put a caliper on it and provide the size bearings you will need (as I said, unless your crank is garbage it should be STD).
    THEN you take that information and order the appropriate size from ACL. And do NOT get the "race" bearings... just get the regular ACL bearings. I truly hope a "mechanic" is not assembling your engine - but we have to use the resources given to us I guess. Mechanics rotate my tires and refill my radiator - lol - they don't assemble my blocks... but if he is competent, once you get the bearings... new bottom end gasket set, rods, water/oil pumps etc he can assemble your bottom end.
    Cobb County
    Is it hard to put these bearings on? I never assembled a engine in my life, so I will definitely be using all the resources I can.
    Northwest Georgia
    bearings just push in with your fingers. if its an ls vtec than get ls bearings. don't turn your crank unless you want to ruin any chance of it being a good performing crank for higher power.
    Quote Originally Posted by SPOOLIN
    that's arguable.
    Also - we're talking about your basic LS/V. If that crank has been stored anywhere else OTHER than the block and/or stored improperly I would get it turned.
    that would be the shop bitch
    LOL @ DaRon
    I dont know anyone who has tunred a honda crank. Just get propper sized bearings or "size the rods"
    MAINSTREAM PERFORMANCE
    Digital Box Tuning
    your moms house
    [QUOTE=BABY J]
    [QUOTE]
    the only difference is the coating on the bearing if you ever see both, the race bearing coating is closer to a factory honda bearing than the std acl bearings.
    i know people than have run them for 20k plus miles. many people think since they say race they wear faster thats not true.
    Northwest Georgia
    the acl race bearing has NO coating. Ive used both, never seen any difference when pulling them back out...except cost.
    Cobb County
    Cool so I will order the whole kit tomorrow then.
    Boost Junky Jordanmd88's Avatar
    Smartest thing i have every heard on IA...
    Honda CRANKS Never need to be turned or balanced, unless the motor has grenaded or the crank is visibly scored.
    Hondas are not Chevy's or Fords with a Cast P.O.S crankshaft
    Honda cranks are forged and can take upwards of 1200bph
    The ACL race bearing also have a Tighter tolerance.. Plasti-gauge some normal ACL bearings and then do the same on the same journal with the race bearing..
    This is what ACL told me when they sponsored my NDRA Pro turbo 4 Honda
    Cobb County
    So do I need to order the whole kit:
    ACL Bearing Kit - B18B
    Includes: Honda B-Series Main Bearings, Honda B18A1/B1, B17A1 Rod Bearing, and Honda B/D-Series Thrust Bearing
    Or just rod bearings?
    Quote Originally Posted by tchill
    I would just order the whole kit, And replace everything while your in there.. I mean hell your already there, and that way everything will be on the same Timeline for wearing.
    Cobb County
    Quote Originally Posted by Jordanmd88
    Sounds good to me man. Thanks.
    DurtyDubs pebojelly's Avatar
    Villa Rica
    Your not to far from Engine Parts Center off Maxim Rd.
    pm me.
    They can sell you a complete bottom end kit for your car or a complete rebuild kit.
    You get to choose a few parts.
    Bearings,Rings and the gaskets.
    I have rebuilt 7 motors with there stuff,from a 1.5 honda to a 351 ford.
    For a v8 I spent 300-400 for the complete kit,with a new oil pump,rings,all bearings,rods,mains,cam.Full gasket set upper and lower + Timing.
    Only thing it did not come with was a rod bolt strech gauge,tourqe wrench and a spring compressor,lol.
    Worth a shot,local and great prices.
    Cobb County
    Quote Originally Posted by 92siLude
    pm me.
    Thanks for the info man. I wish I wouldn't have ordered them already so I could check out their prices. Good times either way though. Reps.
