Results 1 to 24 of 24
Thread: FS: Acura RSX-S Custom Turbo Kit 400WHP+
    Vuong's Garage lxpaulxl's Avatar
    Default FS: Acura RSX-S Custom Turbo Kit 400WHP+
    This kit was pieced by me when I decided to upgrade my turbo from the Greddy kit. Yes, this did come from a blown motor but there is no damage to the turbo or any other parts of this car. The turbo has very little or no shaft play. The motor blew due to failure of the oil pump, causing me to spin a bearing and throwing a rod. I will highly recommend for whoever buys this kit to invest in a oil pressure gauge and either to upgrade the oil pump or run a stiffer spring in the oil pump.
    This kit will come with
    - Precision SC6176S .70 a/r Compressor, .63 a/r Exhaust 5 bolt (only 1000miles)
    - Revhard Manifold
    - 38mm Tial Wastegate /w 5 psi Spring
    - 3'' 5 bolt Custom Downpipe
    - TD Autowerks Dumptube
    - 3 Bar Map Sensor /w MSD 3-Pin Weathertight Connector
    - Greddy FMIC
    - Greddy Type RS BOV
    - RC 750cc Injectors
    - RC Injector Clips
    - Autometer Gauge Pod
    - Autometer Boost Gauge
    - Fast Turbo Oil Lines
    - Greddy Oil Filter Sandwich Plate
    - Unforgettable 3'' Testpipe /w o2 bung welded on for tuning
    - Ebay 3'' Turbo Catback
    - All Clamps, Couplers, Gaskets, Bolts.
    - Hondata K-Pro Map tuned for up to 14 psi @ 93 Octane (Not ECU)
    All you would need to get this kit working is Hondata K-Pro (or a engine management of your choice), colder spark plugs and a 255LPH Fuel Pump and you're good to go. If you would like to make more boost, you can use the K-Pro Boost settings or buy a boost controller.
    This kit made 421WHP and 274WTQ @ 14 psi
    I have invested well over $4000 in parts, misc parts and tuning.
    Asking price: $3300 FIRM
    Price drop: $2900
    Willing to trade for a B series turbo kit.
    Local pickup only.
    Parts of the kit is still on the car but will be taken off ASAP if a buyer comes through.
    If you have anymore questions, feel free to email me at [email protected] or PM me.
