Thread: MOTOR MOUNTS...???
    jupiter
    Default MOTOR MOUNTS...???
    in the market for some aftermarket mounts for my 96 teg. currently pretty stock motor wise, intake/plugs/wires/exhaust/clutch.......(B18B) looking for some opinions or peoples experience, good or bad with any aftermarket mounts...... i am looking at hasport and avid at the moment..dont mind vibrations either!!
    thanks for any input reps will be given!!
    IF YOU HAVE SOME FOR SALE LMK!!!
    jupiter
    bump..............just got home from andretti speed lab...that place is the shizzznit!!
    It's all about JDM.
    CA to GA
    keep your stock mounts, and buy the polyurethane mount inserts...They work well, and a lot cheaper than, replacing for a new hasport or other mount set...which is pointless unless you doing a type R swap or turbo...Just get the inserts, they make engine stiff as heck and less engine hop = better handling, more vibrations, and better performance.
    True But a Biatch to install
    Quote Originally Posted by gsrteg
    dont even get me started. that rear mount what a bitch.
    jupiter
    thats what i am now considering. a set of hasport mounts is over half the price of the B20 i will be buying pretty soon lol................ reps given for input though! so, about the rear mount???? do you have to remove intake mani to access it???? I am a nOOb at this
    No you would have to remove the lower intake bracket , catalytic convertor ,rear mount bracket , but its a tight spot, then you have to re align the tranny/motor back with that bracket an rear mount just some work
