Results 1 to 13 of 13
Thread: 1994 civic hatch project
    DurtyDubs pebojelly's Avatar
    Villa Rica
    Default 1994 civic hatch project
    I got this car monday this week.
    Car was slammed in the fron like no spring and rode like crap.
    Engine bay was super dirty.
    Has 3-4 dents in the top of the car and someone attempted to fix them,the paint is the worst.
    There is some rust in the rear quarters.
    Missing the driver side lip.
    his pic before I got it,cant fully tell but that fron is bottomed out.
    After I raised it up and installed the missing driver side lip
    I am removing the body filler to fix the dents the right way now,going to cut and weld in new quarter Saturday and might go and spray the thing before the end of the month back factory white.
    PURP-a-trader PURP's Avatar
    UMMMMMM... white eg's... I love white... hope to see it finished and G/L
    San antonio 210
    Where did u buy this car ? I think i might know who use to own it...
    Torque is love.
    Charleston, SC
    EG's are my favorite Civic. If you're looking for a really bright, pure white, check out Ford's Oxford White.
    What are you going to use the car for? Weekends, DD, show? What are your plans for the motor?
    Duluth, GA
    pretty good platform to start with. Just make sure you follow through with that plan
    North Augusta, SC
    Nice project. You just going to use it for a DD or ya got bigger plans for it?
    Back to being stock and slow
    한 국
    u sneaky guy u bought this from craiglist didnt you
    C.r.E.a.M MistaCee's Avatar
    Work
    I saw this on Cl. goodluck with it man.
    Villa Rica
    1994 CX hatch no A/C no PS or PW or anything.
    D16Z6 sohc vtec motor swap done about a year ago by previous owner.
    vtec not working and cel on.
    Nice rust in the rear quarters.
    dents on the top near then antenna.
    missing the antenna,driver side lip,front end slammed with eBay junk and way to low.
    engine bay dirtier then a junk yard car,crappy paint on the valve cover.
    Pics of the car as I got it.
    After I got it raised it up and picked up and intalled the dr lip.
    rust in the quarters.
    http://i89.photobucket.com/albums/k2...k/DSCF0052.jpg
    After I gringed some rust away to see how bad it was.Painted with a rattle can to keep it in check until I found replacment panels.
    Struts and coilsovers used to correct the ride.
    Guy I got the car from had 2 sets of ground controls,I sold one set and kept the other.
    Removal of the front end and begin sanding.
    Panels for the rear to be welded in tomorrow and car will be in gray primer wating to get a nice white base clear painted by me.
    Villa Rica
    Yes it was found on CL local.
    I will be DD this with the D16z6 for a little while.
    Next step is either D16 turbo no not eBay junk or B16 swap.
    Villa Rica
    I have one thing I need help with.
    Which lip? and painted or not? Are these headlights and fogs very accurate JDM copies?
    #1
    #2
    No before pictures of the engine bay but here are the new ones.
    Valve cover ordered and new timing belt,crank seal,cam seal water pump on the way through eBay but genuine Honda parts.
    Very dry motor no oil leaks and no grinds in the trans.
    I am going to change the manual trans fluid next week.
    Villa Rica
    car will be in black or gray primer this weekend just waiting to meet up with my buddy tomorrow to see what he has a quart of.
    I am going to let the resigns get out from the body filler and primer before I wet sand and base clear it white again.
    Villa Rica
    I need someones opinion on the lips and info about these headlights and fogs.
