Results 1 to 15 of 15
Thread: car doesnt crank
    Default car doesnt crank
    ok i have a crx and the starter wont kick in. everything else ingage but starter wont crank. its a brand new starter. do you guys think there is a ground problem wiht it?
    check all your grounds including the 1 at the starter.
    1/2 Fast Motorsports highspeed's Avatar
    Gardendale AL
    ^^^^that and have the starter checked at an auto parts store to make sure that it isn't drawing to many amps. is it a "new" reman. or a complete new one? make sure that you know about the warranty and not to void it. its a bad ground, starter, or dead battery....but you have to deduct which one it is.
    Quote Originally Posted by highspeed
    its a new one. and would the igntion have to do anything with it?
    NOTa IA site sponsor seniosoul's Avatar
    @ the computer
    knock on it with a socket wrench
    ATL DA SQUAD MEMBER #27
    Do you hear any clicks or any noise coming from the starter? And when you say everything else engage but starter won't crank,does the car turn over?
    Quote Originally Posted by mp82
    the starter doesnt turn over or nothing. its a brand new starter.
    check your battery fuse
    Quote Originally Posted by wOZrally
    na wouldnt be that. then he would have no power anywhere in the vehicle.
    Take a test light an ground the light an unhook your start ignition wire its the small single wire usually has a rubber boot around it NOT the big one that is bolt onto the starter with the 12mm nut just the small single one...touch the wire with your test light while someone is trying to crank it..If it lights up your starter is bad ...Also check the big wire that is constant power if it lights up also then you have a starter problem....If the ignition wire doesnt light up then you have a problem from that wire to the ignition switch ...Most cases the switch would be bad.... Or if its a five speed the clutch switch under your dash behind your clutch pedal could be bad...you can take the connector off an install a paper clip an that will temp. bypass it BUT REMEMBER IT WILL CRANK IN GEAR AN CAUSE DAMAGE TO YOU,CAR, OR SOMEONE ELSE BE SAFE....Sorry I had to throw that in so you dont kill someone...Hope this helps Joshua
    put your tranny ground back on! LoL bet on that . .0
    or double check it at least
    check your ignition switch
    didnt know if he did.
    but hey i found this website really helpful
    http://www.tegger.com/hondafaq/start...s.html#badcoil
    SOUTHSIDE
    get a small wire and touch the bolted wire on the starter to the ignition wire clip on the starter to see if it turns over at all....make sure its in neutral...if it turns over than its your ignition...
    Quote Originally Posted by wrekonize
    the same thing but JoshuaASE way is a lil safer.
