Results 1 to 4 of 4
Thread: Headlights not working.
    BMW FTMFW
    Default Headlights not working.
    So I pull the lever back to turn the headlights on and all the parking lights/rear lights/tag lights come on but the headlights/fog lights do not come on.
    I tried to turn the fog lights off and still no headlights. I checked all the fuses related to the headlights (1,2,13,14) and they are all fine.
    BUT, if I have the lever pulled out for the headlights to be on the and I flash the brights all four headlights come on. If the headlights lever is pushed in and I flash the brights only the high beams come on (which is normal, i think).
    Any ideas?
    Thanks,
    Jeff
    PS This is on my 1990 Problematic 325i
    Athens/ATL
    may be that just your low beams are out... weird that they would both go out at the same time, but I've seen weirder. It's like when you turn your headlights on regular and one is out, but then you switch on your brights and they both come on. Try just replacing your bulbs.
    **H.I.D KING** Nitro's Avatar
    STMN GA
    u need HID's lol....i keed..i keed
    sounds like u need to replace your headlight switch.
