Results 1 to 16 of 16
Thread: That pesky steering knuckle!!
    SwiperNoSwiping!!
    Angry That pesky steering knuckle!!
    Can't figure out how to COMPLETELY tighten those nuts with the cotter pins in them, because the bolts im trying put them on keep SPINNING with the nut!
    Its basically the one thats on the steering knuckle that i neeed to tighten cuz its making my steering vibrate cuz its not tight enough on there.
    It's all about JDM.
    CA to GA
    you probably stripped the threads...the nut shouldn't be spinnin...you might want to rethread.
    Scottish Scotsman's Avatar
    on the road to recovery
    if you use an impact gun the bolt wont spin , i had to do that a few weeks ago
    SwiperNoSwiping!!
    Quote Originally Posted by gsrteg
    no, it doesnt spin and its not stripped. its like, i continue to tighten the nut onto the threads but the threads start spinnin too which makes for no more tightening.
    lol , read post #3
    SwiperNoSwiping!!
    Quote Originally Posted by TheScotsman
    lol , read post #3
    i know, i was just addressin the other dood's post too lol.
    I dont even have access to an impact or air tool either...
    i know exactly what you are talkin about , the bolt you are puttin the "castle nut" on keeps spinnin sfter the nut gets to a certain point
    SwiperNoSwiping!!
    yep. it soooooooooooo annoying too!
    lol , i know , is this on your DD?
    SwiperNoSwiping!!
    yeah its my projeckt too
    i can bring my compressor and air gun on sat and help if ya like , and lmao , at us postin each others threads , hahahahahahaha
    SwiperNoSwiping!!
    lol nah its okay. plus i gotta go up to this shop in Canton saturday so i can get my car straight to pass emissions.
    Certified Gearhead 4eyedbox's Avatar
    ATHENS
    Its been a while since I have messed with the suspension on a Honda, but I will offer some sound advice anyways. If the ball joint faces upwards (meaning the threads are on top of the joint), simply apply pressure from beneath. I usually use a jack to hold pressure on the bottom center of the ball joint.
    Its slow... I promise
    SwiperNoSwiping!!
    Quote Originally Posted by 4eyedbox
    +1 ill give it a try later on
    u talkin about the ball join that goes into the lower control arm or the ball joint on the tie rod end.
