Results 1 to 19 of 19
Thread: did i mess my clutch or transmission up?
    G0T CH33S3?
    Default did i mess my clutch or transmission up?
    need some help.
    i got a b16 del sol.
    so anyway i let one of my buddies drive my car and we came up on a little hill and got into a little nasty stall.. short while after that he said first gear didn't feel like there had alot of power in it and it would bog at 4k for a little bit then rise rpms. then the weirdest thing happen the car would die as we were driving it. we turned it back on while driving and after a couple of minutes the car would turn off randomly.
    the car now does not start. the battery tries to get the car going but it just wont start
    what happened?
    doesnt sound like a tranny issue. do u have fuel spark and compression.
    G0T CH33S3?
    uh... dont think so
    Quote Originally Posted by deliriouzmc
    uh... dont think so
    dont think so what
    with this post
    need some help.
    what happened?
    followed by this post after someone asked a question
    uh... dont think so
    id recommend you take it to a mechanic. im all for diy but you might need to learn a little more first before trying to fully diagnose this problem
    just my
    Riversider
    it is ur computer, probably gotta a glitch, or even a virus.
    gwinnett
    Quote Originally Posted by Got Milk?
    WTF.
    JDM TYTE AnthonyF's Avatar
    ok, im not going to bash, but seriously. IF YOU DONT KNOW WHAT THE FÜCK YOU ARE TALKING ABOUT, SHUT THE FÜCK UP!
    check to see if you have spart. Pull a plug wire off and put it near somewhere metallic while some1 turns the engine over. Make sure you have fuel by craking open your fuel line ANYWHERE, pref closer to the engine. If you still cant figure it out, take it to a real Mech.
    The Carbon Fibered R6
    Senior Member mccoy1178's Avatar
    check ur dizzy, make sure ur catylic is not clogged GL
    Quote Originally Posted by mccoy1178
    1. i dont think he knows what a dizzy is
    2. why do you think i suggested checking spark (same with mr. f150)
    3. a catalytic converter will not make the car not idle. It'll perform terribly but it'll still start.
    70hp FTL StraightSix's Avatar
    Central, SC
    Not necessarily. My brother had a 1986 or so Buick LeSabre with a 3800 V6 that just died on him one day. The car stumped both my Dad and me as to why it wouldn't start. I had other things going on and couldn't spend much time on the repair, but my Dad kept at it and finally unbolted the cat. Lo and behold the thing fired right up.
    I don't think the cat is the OP's problem, though. The first thing I would check would be spark.
    Georgia Muscle twinj's Avatar
    Da "A" Niccuh
    Is the B16 a swap?
    Do you have any cel?
    Honestly I think that you shook an electrical connection loose somewhere around the alternator if not one that goes to the alternator. You say you stalled out pretty bad as you know thats is a really rough on the engine(shaking & jerking) Is the tach Jumping around when it does these things?
    Just my opinion though(something to think about)
    Quote Originally Posted by StraightSix
    ok, maybe on a RARE occasion...but that is a GM, totally different setup and most cat problems like that are by GM cars. Very odd. But he's in a honda, it is pretty unlikely for this to be the problem.
    he isnt having a cat issue. i put money on it he doesnt have fuel or spark.
    ^prob spark more than likely.
    Atl
    sounds like spark
    credibility and reputation
    Z and Fit Owner
    Griffin
    had simliar problem on CRX, check spark
    actually this happened to me about 3 months ago.....i gutted my cat on the side of the turnpike and drove home after..................doesnt sound like his prob though.
    check the basics....ground? battery terminals?
    Southside of The Jungle
    Hmm check terminals,make sure fuel pump is working just open gas cap have somone turn car to on position.Listen for buzz sound check fuel filter,spark and ecu make sure it aint come loss.
