Results 1 to 14 of 14
Thread: map sensor cel
    1carNfrontOfu
    Default map sensor cel
    My friend just installed his turbo kit on his 94 civic and is getting a map sensor CEL. He says it comes on when he is in boost what could cause this.?
    B20 wat u want to do JDMB20's Avatar
    Macon
    boost it happens to every car that has boost even after it is tunned i do beleive my car was like that and my friends but i think if u chage to a 4 bar or 3 bar or something like that then it wont go off i THINKS BUT NOT 100% SURE
    ONE DAY
    Total Insanity helcat17's Avatar
    macon
    the map sensor can read up to like 11 psi stock but when the ecu sees boost it usualy will kick its self into safe mode or throw a CEL tell your friend to get his car tuned and stop driving the car till then hes going to blow it up when he gets it tuned they will fix that problem
    missing link i think could solve the problem for temp solution to pass emissions or something.
    Quote Originally Posted by helcat17
    Correct
    Stock ECU CANNOT READ BOOST AT ALL. If it CHIPPED it can see as much as 11psi no the stock map sensor.
    Tell your friend to buy an ECU from me and he will be able to boost till the cows come home.
    If he continues to drive on it , it WILL BLOW UP
    god.
    Flowery Branch
    GM 3 bar map...
    02 WRX patrick4588's Avatar
    warner robins
    in to see carnage from blown motor
    GCO Member
    NRA Member
    1carNfrontOfu
    Correct
    How much for the ECU?
    my ecus are $150
    Macon
    good deal on the ecus i just piad 100 for a virgin p30 and still have to get it chipped for my b20/vtec how much mike
    ONE DAY
    P30 an P28s are $80
    macon
    lol me too
    Quote Originally Posted by JDMB20
    if it's happening after it's tuned there is something wrong. it shouldn't happen after it's tuned unless you're tuning w/o a chipped ecu.
