Results 1 to 29 of 29
Thread: Test Pipes?
    Cobra KAI AznTraitor's Avatar
    Afghanistan
    Default Test Pipes?
    okay, I did some searching around and found I can use a "test pipe" to delete the catalytic converter....I am suspecting my stock cat is clogged and a replacement is $400+....
    I am looking at Omni Test pipe...and I guess my catalytic converter is attached to the stock exhaust manifold? does the test pipe just go in place of it? or will I have to get a new header as well?
    sorry, I am new to honda's.
    btw, it's a bone stock D16y7.
    and I do not have emissions here in Columbus....so I am not worried about emission testing.
    uhm the catalytic converter will come off in 4 bolts , 2 on each side...how will you pass emissions?
    Afghanistan
    Quote Originally Posted by Benefit
    we do not have emission testing here in muscogee county...
    so I can bolt a test pipe up to my stock manifold?
    you could just gut your stock cat, but a test pipe will flow better.
    Afghanistan
    Quote Originally Posted by Nick
    I don't really care for power gains or anything like that...
    this is my DD for my 80mile commute, and I just want the best fuel saving possible....
    Don't pollute the air, buy a universal Magnaflow high flow cat (under $150) and get it welded. The HP difference between test-pipe Vs. high flow cat is VERY minimal.
    ATL, GA
    Go the auto parts store. Cats only cost like 100 to 150. Dealers always over charge stuff.
    E-Thug SouthSide Tay's Avatar
    SouthSide Atlanta
    Quote Originally Posted by chituntang
    x2
    - SouthSide Tay
    93 Sonoma
    -350ci SBC/th350/edelbrock single plane intake/holley 600cfm/dual flowmaster/3.73 rearend/ Weld prostars/ 27x8 Hoosier Slicks
    Daily Driven
    70hp FTL StraightSix's Avatar
    Central, SC
    Quote Originally Posted by KevinT707
    The latest issue of Grassroots Motorsports tests several high flow cats against a test pipe and the stock cat on Miata. It's a pretty good read. They also do a gas analysis of the cats tested.
    Afghanistan
    forgive me for being so noobish with questions, but I have no idea about honda motors.
    so, what you guys are telling me, I can unbolt the cat that is connected to the bottom of my exhaust manifold (header), so what do I put in place of empty area? because I know the pipe goes under the car and then there is a resonator then to the exhaust....
    so basically it's
    exhaust manifold
    catalytic converter
    resonator
    exhaust
    but the cat is connected right to the header? I'm sure someone knows what I am talking about
    it's a 97 LX d series motors
    Athens/ATL
    The cat should be in line with the exhast piping.. I don't remember if it bolts directly to the header...
    Unless you have the annoying one that looks like this
    If you do, then you should probably just cough up the cash or gut it.
    PS - Test pipes/gutted cats are louuuud..
    Afghanistan
    see, that's what I have! never seen anything like it....I dont think I can take the cat off of it.
    and no I don't want to cough up the cash for this, because it's my DD...I am keeping this economical as possible, because I only bought this car for my long commutes, not a show car, not a racer (haha) just beating it on the highways
    한 국
    im bout to run test pipe on mine
    YEAH! bRiAnMcIvIcS's Avatar
    Dude just buy a new header.
    turbos
    Quote Originally Posted by bRiAnMcIvIcS
    x2 If your worried about price just get a header off EBAY they are like 50 bucks. Do not go to honda they will :idb: you on a price for a new one
    Certified Gearhead EK Hotch's Avatar
    Canton
    take a ziz-wheel(small abrasive cutter) cut the cat open, destroy the guts, weld/have it welded back together. done.
    Swamp
    Greene/Athens
    gutting it would be the cheapest but if you did that then you might want to put 2 mufflers on or another resonator or s-thin because a 80 mile commute can get very annoying after a while of that sound.
    Deuce Deuce BB1_Luda's Avatar
    Just take off the header.
    And gut the cat. Take all the material out.
    Simple, Free, better gas mileage.
    Member
    Carrollton
    I've seen this done on a EK civic.
    The car gained 7whp on a dyno.
    Which leads me to believe the cat was clogged.
    98 Subaru Legacy GT
    89 325i. 400hp hoon-mobile.
    Yum-Yum Racing
    buy a set of ebay headers
    turbos
    Quote Originally Posted by BB1_Luda
    x2
    Afghanistan
    got a ex stock header today, so I'm gonna put that on and get a high flow cat welded on
    Cambodia
    I'll give you 10 bucks for your old cat if you haven't gutted it.
    Afghanistan
    Quote Originally Posted by iNsTuN nOoDoH
    you do know it's not the regular "cat" right?
    it's this one...
    if that's what you need, then sure...10 bucks sounds great. but I'm not gonna deliver this bad boy, it'll go as far as columbus or newnan.....so it's basically how far you are and how bad you want it.
    just gut it out
    Afghanistan
    just gut it out
    nah, already got a EX header that doesn't have the cat attached to it like the pictured one....
    I rather just bolt and go.
    Go Dawgs
    SouthSide
    test pipe FTW
    Tuned by Lil Ray Ray's
    turbos
    i do believe you is tryin to make a quick buck. i can sell used cats for $$$
    chamblee
    gut the cat man
