Results 1 to 20 of 20
Thread: How do you advance the timing on a 93 miata?
    Might be unstable MskunkM's Avatar
    Duluth, Ga
    Default How do you advance the timing on a 93 miata?
    this is the one thing i cant figure out by myself.. any suggestions?
    Zombie panda BACK IN BLUE
    i did a timing on 1 the other day. just follow the helms or whatever manual u got. 1 thing to make sure u look at is the key way on the crank sprocket. the 1 i worked on took forever to figure out why the timing was off 1 tooth. come to find out it had a weak crank and the key way got ate up.
    JDM TYTE AnthonyF's Avatar
    take it to a professional. Get your car tuned and they will do all the work.
    The Carbon Fibered R6
    DUH-KYOO-LUHHH
    www.google.com?
    ^hey, got bite a finger
    Duluth, Ga
    lol google didn't do **** for me!
    DUH-KYOO-LUHHH
    no hablo? wtf is got bite a finger sposed to mean? lol
    Quote Originally Posted by MskunkM
    it did for me... go to the flying miata tech articles. basically all your doing to it is moving the CAS. i should have thought about that since a traditional dizzy is that sensor and the coils all in one peice, i just didnt eat my wheaties yesterday.
    Duluth, Ga
    Quote Originally Posted by jesse4846
    well now youve done that you know premium gas is the ONLY gas you should run now... ive been told that MANY TIMES
    DUH-KYOO-LUHHH
    thats why i didnt do it lol
    i just wanted to know.
    and the reason for the premium gas only is because it has a much higher resistance to pre-detonation due to compression, or "ping" as some people call it. detonation can cause the combustion chamber to heat up wrong and basically turns your car into a 4 stroke diesel. since it ignites closer to TDC, it must be able to compress more to fire properly. i run mid grade in my car anyways, since its a VERY high mileage motor, and carbon buildup in the combustion chamber can actually increase compression and cause hotspots, making the car more likely to ping.
    everywhere & nowhere
    trade it in for a 94
    a little past half way down the page. use vehicle specific forums for better answers next time http://www.miata.net/garage/ignition.html
    Senior Member metalman's Avatar
    jump the 10 and ground in the diagonostic connector with a paper clip
    loosen CAS bolt
    Attach timing light
    start engine
    move CAS to correct/desired timing as determined by light on crank markings/indicator
    tighten CAS bolt
    remove jumper from diagnostic
    finished
    Car Troika gforce23's Avatar
    Yep, what metalman said. Here's a more detailed explanation:
    EDIT:
    Sorry, I never saw redrum's post.
    lol i just noticed i read the title all wrong. i thought u was asking about the a timing belt job. duh me. since thats the case.
    Quote Originally Posted by metalman
    loosen CAS bolt
    Attach timing light
    start engine
    tighten CAS bolt
    finished
    hes correct
    Duluth, Ga
    ID LOVE TO but im in love with my miata i cant part with her easy for sure.
    ??? that made no sense???? i was giving you a link to miata.net the garage section where it tells you how to do the timing. i could tell you how to do it for a 99 though, but it will not be anywhere near the same as your motor
    Duluth, Ga
    i think i posted that last comment with the wrong quote.... or something....
    Duluth, Ga
    ANYWAY PROBLEM SOLVED.... HEY MODS YOU CAN DELETE THIS NOW
    whats your stock compression ratio?
    Duluth, Ga
    no idea off the top of my head.. ive got it written down somewhere...
