Results 1 to 10 of 10
Thread: gsr rods in a ls block..
    Senior Member kaotickaozpunk's Avatar
    Default gsr rods in a ls block..
    can gsr rods be used in a ls/vtec setup..ls crank with gsr pistons and rods...yes i already know the gsr rods are much longer than ls..but what is the compression ratio if possible..but would it hit the head...will the rods be too long..anyone done this setup lmk..im wondering too much...
    DA SQUAD # 13
    Augusta, GA
    the rods will be a little bit shorter, resulting in less displacement, and isn't the point of ls/vtec... i'm sure it has been done before...
    gsr rods wouldnt work on with ls crank. if u put a gsr crank in it would work but then youll just end up with a really crappy gsr. if im wrong somebody correct me.
    Don Mon SiRed94's Avatar
    Morrow 30260
    why???
    your moms house
    no
    Girls Do It Better!! DC2girl's Avatar
    Look behind you dude!
    but the good part is you can do the opposite, using a ls crank, rods, etc. in a gsr block which would put it at 89mm stroke I believe. Golden eagle makes a kit for that to plug the oil squirters.
    1999 Honda Civic EX - SOLD
    no
    GSR rods wont work on an LS crank and vice versa
    YEAH! bRiAnMcIvIcS's Avatar
    Quote Originally Posted by vtec_hawj
    LMAO!!!
    Northwest Georgia
    the gsr rods are considerably NARROWER then LS rods and journals so that would be really BAAAADDDD. Its impossible to even fit an LS rod onto a gsr crank.
    Out in the Boonies
    nope you'd have to use ls rods with gsr pistons on the ls crank .. but that's just a waste of time, money, and effort.
    You can, however, use the ls crank, rods, and pistons in a gsr block. Just either you'd have to but the golden eagle kit, or you can just heat up the oil squirters and tap it gently with a hammer.
    you can find a thread about it here:
    http://www.honda-tech.com/zerothread?id=1837872&page=4
