Thread: Dad's Prelude just died, help
    Monore/Atlanta GA
    Default Dad's Prelude just died, help
    My sister was pulling out of the driveway in my Dad's 92' 4 cyl prelude. She said she got to the top of the driveway and the car shut off and all the dash lights lit up. She rolled it back down the drive and parked it. My Dad went out and tried to start it. He said it will start and run for a second as long as the key is turned in the start position with the starter spinning, as soon as you let off the key and the key goes into "Run" position, the car shuts off again.
    What is the issue? Throttle position sensor maybe? Ignition switch?
    Anyone had that issue?
    01' Mercedes C320 $10500 o.b.o. or trade 4 G35 coupe
    http://www.importatlanta.com/forums/...9#post38098929
    athens
    out of gas maybe?? or..have u run it hard lately? any work done on it recently?
    Not the TPS... Not the Ignition switch since the dash lite up... take it to a shop... Maybe the dist or ecu
    Monore/Atlanta GA
    Quote Originally Posted by chip P.
    nope, have been driving it for months now. Something esle.
    Monore/Atlanta GA
    Quote Originally Posted by del Slo
    But it will run, just not once you let off the ignition switch. Not the distributor or ECU if it will run.... Gotta be something different
    buford,ga
    pull ur plugs and take a look at em... could be the coil
    94 si h23a1
    GPC member #2
    Z and Fit Owner
    Griffin
    electrical problem, check battery, plugs, ect.
    Monore/Atlanta GA
    Ended up being a corroaded battery terminal. All is well with the lude again
    San antonio 210
    Quote Originally Posted by jwrape
    damn thats what i was about to say. Terminal or ground...
