Results 1 to 15 of 15
Thread: b20 vtec
    B20 here i come
    mcdonough
    Default b20 vtec
    how reliable are b20 vtec and is there any real problems with them
    also if u rebuild it for race then is it good or bad
    thanks
    Don Mon SiRed94's Avatar
    Morrow 30260
    it is as reliable as you build and drive it...
    Quote Originally Posted by SiRed94
    thats it in a nut shell. u drop in a stock b20 vtec and rev the piss out of it good luck. build it a lil before u drop it in or dont get all vtec crazy and u stand a good chance of having a reliable motor.
    Cobb County
    The only bad thing I've heard about building a B20/VTEC for high performance is that they have thin sleeves.
    Proud Mr2 Turbo Owner
    Subherbs
    b20/vtec, and ls/vtec can be reliable.
    i have heard so many retarded people say they have to many problems. They have problems cause the people who built them, don't know what they are doing.
    just do it right. and you won't have an issue
    1996 4dr Integra
    1992 Mr2 Turbo
    RPM = Ruins People's Motors
    THE YANG BROTHERS
    nc,Hickory
    Default arteg6
    yep he says it all..........................
    Certified Gearhead ATLem1's Avatar
    west
    Quote Originally Posted by Mr2raceworks
    exactly.. my personl experience: 5 years, about 50k, great power, 30mpg, never had to open it. leaks nothing.
    its all in how you put it together. do it right, do it once.
    Senior Member Code-Aye's Avatar
    hahaha
    Quote Originally Posted by ATLem1
    x2 thats what im gunna do if i get a b20/vtec
    Southside
    yup keep the cost down and the mods mild and your wallet wont be exhausted
    B20 wat u want to do JDMB20's Avatar
    Macon
    ummm. ya i alreadybuilt it and found out all the info i need i broke 203 to thw wheel and not done till i have 220-50 all motor and tryin not to spray but i might have to
    ONE DAY
    Newnan
    be careful hitting vtec all the time, those rod bearings don't hold up too well in high rpms, had it happen to me w/o vtec. people said it would handle 7k all day and I never brought it past 6500rpms but developed a rod knock anyway with black and blue bearings
    the 'Ham
    i have a friend doing a B20VTEC swap now. i chose not to do the head swap and did a 75 shot. head was remilled and ported w/ a 5angle valve job. Crower 404-2 cams, ARP head studs. i made 203 / 197 @ the wheels. 156 / 148 NA. (that was stock injectors, and pump gas. i've got RC330ccs' now and 106 octane to mix on the next tune) my friend is wanting 180ish+ whp. *shrugs* we'll see.
    B20B/B18C1
    Quote Originally Posted by TR_Accord
    That has nothing to do with VTEC or RPM.
    I revved my stock GSR block to 9900rpms for oh i dont know, about a year. then i sold it, then someone else drove it for about a year before the oil pump failed.
    If your motor rod knocked it was because of an oil pressure failure or an incorrect bearing size
    Out in the Boonies
    We found out that the problem was that someone had switched the #1 and #4 bearings in the block. The #4 bearing was too lose which caused it to spin, and the #1 bearing was too tight in which the crank and rod ate it up. So we'll have to go with a new crank and rods.
