Results 1 to 19 of 19
Thread: header hitting on tunnel
    DUH-KYOO-LUHHH
    Default header hitting on tunnel
    the stupid ebay header that came with my car is hitting the wall of the tunnel on the driver's side when i put the motor under load and the p.o.s. rubber mounts flex. anybody have a solution? i was thinking putting some exhaust wrap on it to close up the gap between the sheet metal and the header, since its only a 1/16th of an inch gap at best...
    any other ideas? im hesitant to break out the ford wrench and start bangin away on either the tunnel or the header...
    middle ga
    Quote Originally Posted by jesse4846
    ebay is good for somethings..headers are not one of them
    DUH-KYOO-LUHHH
    Quote Originally Posted by japan4racing
    wasnt my choice lol... came with my car and i like it better than stock... except the BAM BAM BAM from it hitting the chassis...
    middle ga
    sell it and get a real header..and by real i mean a turbo manifold!!!
    DUH-KYOO-LUHHH
    if i had a turbo maybe...
    thats all
    on what car?
    is better than you..
    Somewhere you're not
    Quote Originally Posted by mp82
    on what car?
    judging from his avatar and talking about a tranny tunnel....i think its a miata or some other rwd car...
    didn't even notice that..haha cut and weld
    Heckler Dietcoke's Avatar
    Richmond Hill, GA
    BFH the tunnel.
    2011 Camero - Fast
    1998 T/A - Slow
    DUH-KYOO-LUHHH
    hammer on tunnel = no more full throttle due to inconvenient placement of the contact point...
    bend the throttle out of the way
    DUH-KYOO-LUHHH
    dammit man im trying to avoid brute force if at all possible lol.
    i really just need a little strip of heat shield wrap and all my problems will be solved...
    Earth
    If you know the answer already then why post a thread???
    DUH-KYOO-LUHHH
    i was just seeing if anybody had any other helpful input. like a cheaper way to do it without using a BFH, such as a different flame-proof material
    Earth
    Ahhh, just wrapping it with it still hitting the tunnel is gonna put strain on the studs... New header or BFH.
    DUH-KYOO-LUHHH
    im more willing to bfh the header than the car...
    grind the welds out then slightly reposition the tube and get it welded back together.
    Turbo-Wired
    East Cobb
    How about replacing the mounts with urethane?
