Thread: need help w/ Type r tranny
    N/A yeah!
    Default need help w/ Type r tranny
    so as it is my brother just bought his type-r swap and stupid me had to just test it and so, i took off on 1st gear, then as i was going to 2nd it grinded,stripped,or wut ever u wanna call it i missed gears and still tried to force it in, anyways after that the clutch went and my brother changed it then now it wont go in any gears at all but it still moves around when he moves the stick shift around. If you know anything about it plz give me some pointer on whats wrong and how much to fix it thx
    92 EG GSR Supercharged sold
    93 EG JDM Type-r- GONE 2 Bro
    Girls Do It Better!! DC2girl's Avatar
    Look behind you dude!
    slow down....
    you have to be a little more specific. Does it go in and out of gear when the car is off? or it doesn't go into gear at all. There's too many variables, it could be the throw out bearing, slave cylinder possibly, did he install the clutch correctly? using the allignment tool.
    1999 Honda Civic EX - SOLD
    so with the car on you CANNOT change gears at all? and with the car OFF you can shift from 1st to 5th to reverse? you prolly might just have to bleed your clutch system so that the clutch fully disengages, or your pressure plate may bad or damaged
    I would take it back apart, inspect the clutch and pressure plate. If it's bad then I would replace the clutch assembly, resurface the flywheel, new pilot bearing, and throw our bearing. Make sure to use the alignment tool, torque the pressure plate bolts (19ft-lbs), torque the flywheel bolts (76ft-lbs), make sure you have enough tranny fluid (2.3qts honda mtf).
    Unknown
    it doesnt go in when its on/off and yes he installed it right
    Quote Originally Posted by DC2girl
    slow down....
    Unknown
    everything was down as u guys said the only thing is that could it be b/cuz its an ebay clutch, but wut about the F**king up on the second gear when switching
    Yum-Yum Racing
    throw out bearing is possibly jammed or the pilot bearing def go ahead and replace the pilot bearing
    ATL represent
    I'm going to vote for a bent shift fork and probably a throwout release fork as well.
    Pull that tranny and bust it open and you'll likely see the 1-2 shift fork is fuxd.
    bleed the slave
    N/A yeah!
    talked to my bro again and he said, he had the clutch in then drove it and when he went to throw it in 3rd gear he said he heard something fell in the transmisson like dropped i guess so he dont want to open it up b/cuz it might get f**ked up
    Atlanta, Ga
    Quote Originally Posted by type-r swap
    sounds like its already "f**ked up" sir. your either going to have to take the tranny off or put the car in the garage to collect dust.
    g/l with that
    N/A yeah!
    so do i have to replace with new tranny or fix it which would b cheaper
