Thread: Blow off valve vaccum question
    Soul Crusher RUFFIAN's Avatar
    in your nightmares
    Default Blow off valve vaccum question
    Is a blow off valve supposed to stay open under vaccum(I.E. at motor idle) I have upgraded the spring and I still am having idle problems. I need this bastard to stay closed until I lift off of the gas. This is pissing me off and I am running out of ideas. some one please help.
    N/A>>><<<BOOST
    AWD OH MY KPowerEP3's Avatar
    Ellenwood
    are you venting or recirculating?
    The Nissan KING! R32Dragon's Avatar
    Sumter
    What kind of car?
    Have you 100% isolated the idle issue to the BOV?
    Also did you make sure the actual BOV valve is not just stuck in the open position?
    How does it run with Vacuum line out?
    Daily - '03 Infiniti G35c Sport
    Power - '03 Mitsubishi Evolution VIII
    Beater - '97 GMC Jimmy
    in your nightmares
    Quote Originally Posted by RX8Dragon
    What kind of car?
    A Merkur XR4TI (2.3 sohv /Hahnracecraft super20g)..... there are no other leaks....... the idle smooths out when I unplug the BOV.....no it is not stuck open. it only opens when I put vaccum to it.
    N/A>>><<<BOOST
    Turbo-Wired
    East Cobb
    Quote Originally Posted by RUFFIAN
    ...If I'm reading this correctly, then my assumption is going to be that you need to re-pipe the tubing to your BOV, or replace your BOV. Without a much more detailed description of exactly what's going on, I can't say any more.
    However, at idle your car produces a significant amount of vacuum. Also, I'd suggest switching from a BOV to a Diverter and recirculating your air either way.
    Toyota Tech
    Dec 2003
    Claxton, GA
    what kind of blow off valve? some are known for leaking.
    2010 Scion xB
    Total Insanity helcat17's Avatar
    macon
    sounds like you really just need to replace your bov to me at idle it should be closed
    Don Mon SiRed94's Avatar
    Morrow 30260
    you could put the MAF Sensor on the intake side of the turbo and recirculate the BOV....
    02 WRX patrick4588's Avatar
    warner robins
    just recirculate your bov. if its connected to your intake, you shouldnt have any issues
    GCO Member
    NRA Member
    in your nightmares
    I finally just went with a new BOV. the other one was to much of a pain in the ass.
    N/A>>><<<BOOST
    explain the idle problem?
    in your nightmares
    The system I have on this car is a "closed loop system" meaning that it is metering the air before the throttle body. any air escaping makes the car try to replace it. hence the rough idle.
    N/A>>><<<BOOST
