Thread: keeps blowing ECU fuse
    Yeah its a 4 door
    Default keeps blowing ECU fuse
    alright guys i just finished a swap in my car. everything was fine while driving for about 30 minutes with no check engine lights or anything but then all of a sudden an engine light came on and then it immediately died. i checked all of the fuses and noticed that the ECU fuse was blown i replaced but as soon as i turned the igniton 2 clicks the fuse blew again, so i tried all of my spare fuses and finally on the 15th fuse the thing started and then 10 minutes later the same thing happened. Any ides what it could be???? ive had the suggestion of a bad main relay??? i checked all ecu wires to make sure its not grounding out and the harness is fine no cut or wire showing
    Earth
    My knowledge of wiring is limited, but when you say checking, do you mean just a visual inspection? Double check all the grounds and make sure you are making good contact, no paint, grim, etc.. In the way.
    Earth
    If all else fails move to a larger fuse...
    kidding.
    Earth
    Also it might help others that know more than I, what swap, what ECU, blah, blah, blah.
    athens
    check your grounds,,,
    Yeah its a 4 door
    turns out my 02 sensor wire was hanging down a little and melted on to the down pipe causing a short but thanks guys
    heater circuit.?
