Thread: changing sparkplugs
    Gwinnett-Grayson
    Default changing sparkplugs
    how often are you supposed to change them? sorry if this is a stupid question. also, where the **** are they on the motor, sorry for the other stupid question
    Canon Nutswinger:
    Canon XS
    18-55mm
    55-250mm
    50mm USM
    just like any other engine, they should be under the valve cover connected to the bottom of the wires. just pop off the wires from the engine and you'll find them.. oh, and I try to change mine every 60,000mi, but that's just me. I heard somewhere that you should replace them 90k mi
    Southside ATL
    What year, make, and model is the car?
    What engine do you have?
    Copper plugs should be changed every 30,000 miles, while platinums can go as long as 105,000 miles.
    We need to know what engine you've got in order for us to help you better.
    He has an LS engine.
    Spark plugs will be under the Spark plug wires on the valve cover
    Southside ATL
    Stock plug number will be an NGK ZFR5-F11 - and like Batl said, they're under the plug wires.
    1. Pull the wires out of the way
    2. Grab up a 5/8ths deep well socket and remove the plugs
    3. Add a dab on anti seize to the new plugs' threads
    4. Start each one by hand and tighten them - don't over tighten them
    ...and again factory plugs for a B18A/B engine are coppers, which need to be changed every 30,000 miles.
    If the car is boosed I'd check and possibly change them every other oil change, depending on if the set-up is tuned and if the engine runs rich. lean, or burns any oil.
    generally every 30-40k miles
    IA Member Joelow30071's Avatar
    Paradise
    i run denso irdiuims under my hood. cost me a hefty price for each one from autozone.
