Results 1 to 11 of 11
Thread: Car Dies
    I don't pull out... E=MC˛'s Avatar
    Where we like our sisters...
    Default Car Dies
    95 DC2. The car starts just fine in the mornings. I drive it until it gets to running temp. I hit the clutch to stop and the car drops under 500 rpm and dies. i.ve checked the battery and ground. is there anything else i should check. anyone ever had that this happen to them?
    any vac. leaks?
    Default car dies
    no not that i can find. it idles fine. i could go start it now and let it get to temp. hit teh gas to 3 or 4k let go and it die.
    It's all about JDM.
    CA to GA
    maybe have to adjust the idle on the intake manifold/throttle body....
    check the thottle body to see if it get stuck close try adjusting the thottle cable
    southside ATL
    check if you have good compression..it might be somthing serious or might be somthing not
    BABIES "R" US crew
    the old man NAIZBST's Avatar
    check for vacuum leaks or the IAC valve
    try sprayin the throttle body with carbarator cleaner. however u spell that word.
    athens
    have you had any clutch work done recently?
    clean your IACV. come on people don't try to offer advice if you don't know what you are talking about!
    L'ville
    i'm with chris up there^ IAC is sticking shut when the car drops in rpm's too quickly
