Thread: boost noob..
    Under your bed.
    Default boost noob..
    okay so i have an ls motor in my 92 civic 4 door...
    and im wantin to do my first boost job... wooohooo... lol
    anyhow..
    i have the turbo kit and all...
    im pretty set on hjow to do it but im not 100% sure on how im suppost to tap my oil pan...
    do i drill it and put the t fitting in? or what?...
    and any pointers y'all can give me would be great...
    reps givin for any help...
    AWD OH MY KPowerEP3's Avatar
    Ellenwood
    Drill the correct size hole, tap the threads.
    I also recommend some kind of thread sealant, preferably blue loctite. [blue because it will help seal, but if you ever need to remove it, it breaks loose easily enough that you won't kill yourself like with the red], although some just use teflon tape.
    Also, make sure you get ALL of those metal shavings out, but I'm sure you knew that.
    Unless you've got the 2 piece fitting, then just drill, put the fitting in, and put together with loctite/other sealant around the edges and on the threads on the fitting.
    Under your bed.
    Quote Originally Posted by KPowerEP3
    okay man thanks...
    and also on the fuel management unit do i need to run hondata? i got a walbro 255 fuel pump, and probably 440cc injectors
    i'm a got dang wallaby!!
    there are other options out there other than hondata what are your goals? purpose for using hondata? what about a V-afc? Emanage? Power FC? AEM's new Fuel comp?
    Under your bed.
    im lookin to make 200-250 nothing major..
    still running the stock ECU and such? just need additional fuel? are you a person who wants to set it and forget it? or you a constant tuner?
    Under your bed.
    this is just gonna be a temp set up...
    im going to build a gsr and do it all right...
    im just going to use the stock ecu...
    i just need to add more fuel
    if you wanna hold on about 2 weeks or so i'll have my emanage for sale, wires etc etc send me a PM if your interested. its a laptop tuner, it has alot more fuel parameters than the Vafc's BUT it doesn't do the Vtec thing which by the looks of it your LS doesn't have so if your interested in going that route i'll cut ya a good deal on it. but if not i'd say invest in a VAFC and use the AF part of it right now then when you boost on the GSR you can use the Vtec engagement part of it. so its really up to you but if you're looking to save some cash now and get something with a better... "air/fuel mapping area with closer details Emanage, if your looking for basic AF duties and Vtec later on get the Vafc"
    Ellenwood
    Well, regardless of temporary or not, I'd say go ahead and have the ECU chipped/tuned. But with a walbro, larger injectors, and an AFPR, you could probably get away with pulling fuel out using a piggyback controller. Like I said, though, I'd say go with a real tune, ether way. Just remember, there ARE other options besides Hondata, a lot of which are less expensive and just as functional.
